Page 4 of 4 FirstFirst 1234
Results 76 to 97 of 97
Thread: Build Log – Corsair Obsidian 800D Liquid Cooled Dual Loop System
  1. #76
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    When you'll receive them i'd love to see comments how resistive are these for 580. IIRC ones for 480 were most resistive from all 480 blocks tested by skinneelab.
  2. #77
    Jun 2009
    Parker, CO
    Quote Originally Posted by churchy View Post
    Well I will report what I can regarding temps and such, but I don't have the tools at my disposal to measure Restriction / Pressure Drop like Skinnee Labs does. The blocks looks like a complete redesign from the 480, so hopefully they performs better as well.
    If you would like to see the internals of this block, hit up this link
    http://www.evga.com/forums/tm.aspx?m=685866&mpage=1
    Project Turambar: Corsair Obsidian 800D Liquid Cooled Dual Loop System
    Corsair 800D ~ EVGA X58 Classified W/C EK-FB EVGA X58 Full Board Block ~ Intel i7 Core 970 @ 4.2Ghz W/C Swiftech APOGEE-XT Extreme
    12GB Corsair Dominator @ 1600MHz ~ Corsiar HX1000 ~ EVGA GTX 580 Hydro Copper (x2) SLI ~ EVGA 9800GT (PhysX)
    SSD(OS) Intel X-25m 160GB ~ HDD(User Files) Segate 500GB ~ HDD(Game Installs) Samsung Spinpoint F4 1TB ~ HDD(Storage) Seagate 2TB
    Creative X-Fi Titanium Fatal1ty ~ Windows 7 Ultimate x64 ~ Dell Ultrasharp [ 20"][ 24"][ 20" ]
  3. #78
    Jun 2009
    Parker, CO
    Temps and Benchmark Scores
    I have updated my build log with the GTX 580s, and will reserve this post for Temperatures and Benchmark scores as I have a chance to run them. To check out the new pictures, just take a look at pages 1-2 of this thread.
    Ok, temps are great at the stock clock settings for the Hydro Coopper 2 (GPU @ 850Mhz). I was freaking out at first because both my 580s were at 75°C and climbing while just idling on the desktop. Gave my rig a "jiggle" and must have released an air bubble because the temps instantly dropped down to the low 30s. After that ordeal I ran a few quick benchmarks to test temps.
    Heaven DX11 Demo/Benchmark @ 850MHz - 60min Loop
    API: DirectX 11
    Stereo 3D: disabled
    Shaders: high
    Tessellation: extreme
    Anisotropy: 16
    Anti-aliasing: 8
    Full screen: Yes
    Resolution: 1920x1200
    During this 60min loop my Hydro Coppers never hit over 52°C.
    Crysis Warhead Bbenchmark (by FRMEBUFFER) tool @ 850MHz - 30 Loops
    Mode: ENTHUSIAST
    64-bit: Yes
    Display Resolution: 1920 x 1200
    FSAA: AA 16x
    Loops: 30
    Map: ambush
    Time of day: 9
    During this 60min loop my Hydro Coppers never hit over 49°C.
    Temps are doing great. I will work on overclocking these cards this week and will report back with actual benchmark scores and additional temp info at that time.
    I was wondering if it would be worth running my 9800GT as a dedicted PhysX card with the 580s in SLI. Ran two benchmarks to test it.
    CryoStasis PhysX Benchmark Tool
    GTX 580 in SLI + 9800GT Dedicated to PhysX
    Settings Maxed
    Average FPS: 109.6
    GTX 580 # 2 running PhysX while in SLI Mode
    Settings Maxed
    Average FPS: 97.2
    Batman Arkham Asylum in-game Benchmark
    Settings Maxed
    Average FPS: 79
    Settings Maxed
    Average FPS: 73
    With both of these PhysX tests, I still gained a few FPS when using my 9800GT as a dedicated PhysX GPU. Glad to see those results, it will stay in my build. More benchmarks and temps to come over the course of the week.
  4. #79
    May 2009
    Incredible build man, thanks for sharing.
    I'm interested in the vinyl dye for the PSU. Could you explain how to do that and where to get the dye from?
    Also, could you post your temps with that mobo waterblock? The E-leet VREG temp or the BIOs temps would be greatly appreciated as I am considering doing this block again.
    Lian-Li PC-P80
    EVGA X58 CLASSIFIED 759
    PC Power & Cooling 1200W Turbo Cool
    Intel i7 920 4.2GHZ
    Tri-SLI EVGA GTX 285 FTW's
    Corsair Dominator GT (3x2GB) PC316000 8-8-8-24
    Creative SB X-Fi Titanium Fatal1ty Professional
    2x 300GB Velociraptors in RAID0
  5. #80
    Jun 2009
    Parker, CO
    Quote Originally Posted by ///M3TZ View Post
    VHT SP941 - VHT Penetrating Vinyl Dye - $8.95
    My 24/7 OC for my i7-970 is 4.228GHz. At that frequency, the VREGs idle at 41C, and at load they hit around 55C. The EK block for the X58 Classified does a great job at keeping things cool. Once I go higher with the OC, the temps go way up, but are still manageable for benching and such.
    At 4.2GHz
    CPU 16 / 46 C
    ChipSet 16 / 45 C
    VREGs 41 / 55 C
    At 4.6GHz
    CPU 26 / 83 C
    ChipSet 27 / 81 C
    VREGs 47 / 70 C
  6. #81
    Jun 2009
    Parker, CO
    Well I was able to get the cards to post at 1GHz, but found that they were not benchmark stable at that frequency. The temps were fine (low 60s) even at a voltage of 1.138V, but just wasn't stable. Same at 975MHz. The second GPU test on 3DMark Vantage crashes at that frequency.
    950MHz works great in benchmarks, but I don't think I want to keep it there for my 24/7 setting as I have to crank the voltage up pretty hight to achieve that clock. 925MHz seems to be my sweet spot for daily use @ 1.1125v. Was able to throw multiple benchmarks and games at them in SLI, completely stable and never got above 54C at any point. The blocks seem to be performing just fine. Looks like it will be luck of the draw if you can get any 580 that can run a bench at 950MHz or higher. Some guys have been able to to do it without many problems, others can't.
    Ran Heaven DX11 benchmark for 30 minutes, then ran 3 loops of the Crysis Warhead benchmark maxed out with Enthusiast settings @ 1920x1200 with 16X AA. High temp during the entire process was 54C, and my Average FPS in Crysis was 81.21FPS. Loving these cards.
  7. #82
    Mar 2008
    Idaho
    Lookin' good, man! What a nice update.
    Workstation/Playstation: i7 920 D0 @ 3.8, TRUE, EVGA x58, BFG GTX 295, WD 640x2 in RAID 0, 12GB OCZ DDR3, ATCS 840, Dell 24" & Samsung 19", Razer Lycosa and Logitech G9r, HTO Striker, Windows 7 Ult. 64, Antec TruePower 1000w.
    Wife's Computer: E4500 @ 3.0GHz on 1.36v, Rocketfish CPU Cooler, Foxconn, 4GB Corsair, Sea 250, Antec Sonata w/500w, ATI 2400, 17" Samsung, Vista Ult. 32.
    HTPC: X2 2400BE, 500GB + 750GB + 80GB, ATI 3450 Hybrid CF w/Asus 780G, 4GB A-Data 800MHz DDR2, 32" Westinghouse, XBOX 360 HDDVD (w/o xbox), Aver DTV Tuner, Huappage DTV tuner, Windows 7 32 bit.
    PDAs: iPod Touch 16GB and Samsung Omnia
    See my work log here: PROJECT ATCS 840
  8. #83
    Jun 2009
    Sweden
    Some one (back stage working administrator?) have made me really confused by taking away my post as well as the naive and disrespectful answer of a certain young man that I was in the way to answer, or is it me that got totally out of my 56 year old mind.
    By the way I forgot to say that the post regarding SilverStone TJ11 case was my mistake since I wrote that after been up for some 48 hours without sleeping so it become in the way as I thought I wrote a PM to the person in mind.
    In another word My Mistake, sorry for that Extreme Systems Administrator.
    WOLF.
    Last edited by TWP-WOLF; 01-26-2011 at 03:01 AM. Reason: My PC have more and better RAM then me!
    The WOLF is Neither People's Competitor Nor His Enemy. The WOLF is a Fellow Creature With Whom The Earth Must Be Shared.
  9. #84
    Apr 2011
    Aarhus C
    Nice Case
    Hello MR. A
    First off all i will tell you that it is a really nice case mode you've made. I'm really envious of it is not mine. I have something less about it, but certainly not the same as yours.
    Have you even bought fittings from bitpower? or did you get sponoret them? Like real they are expensive, but overall nice ..
    I was wondering, in picture 4 of the final result. How did you get the colors of the snakes so powerful? Which light do you use? Do you only fan light and the two stern light which is in front?
    Furthermore, the small 240 radiator enough to cool your two 580? .. You may even tell if they are switched off and you sell :-)
    Thump up for you Mr. A. Nice work blog and system you have.
    / / Niel
  10. #85
    Jun 2009
    Parker, CO
    Quote Originally Posted by Niel View Post
    Hello MR. A
    / / Niel
    I wish I was sponsored, but sadly I am not, and I had to purchase every BitsPower fitting on my own. SideWinder Computers has pretty good prices compared to most.
    Using two (2) UV Cathode tubes to achieve the lighting in the case. Both are located on the side panel next to and above the window.
    The 240 Rad does a great job keeping my overclocked 580s nice and cool. Temps never get above the low 50s even when stress testing with FurMark.
  11. #86
    Jan 2010
    Awesome build. I want those graphics cards so badly the single slot is so sexy!
    Internal Watercooling Antec 900 Build Log*
    WC loop: Black ice extreme 240 radiator, XSPC 120 radiator, HK 3.0, D5 pump with Bitspower top, DD fillport, Primochill tubing, distilled + ptnuke
    Pink Floyd is #1
  12. #87
    Apr 2011
    Aarhus C
    have you tried to play BC2 and extreme gaming for the gpu?
  13. #88
    Apr 2011
    Aarhus C
    Mr. A..
    If you are going to sell the two gfx 580, because of the 590.. Please give me a pm. I am really interested
    Thumbs up for the good work! :-) Can΄t say it enough
  14. #89
    Mar 2008
    Idaho
    Mr. A..
    Not likely. He's a single-GPU per card kind of guy.
    I have really been pleased with my 295, and it was fantastic bang/buck, but that's usually not the case, as most dual GPU single card parts have too many drawbacks to justify the extra cost and heat envelope. Even the new ones are not a great value, from AMD or nVidia. Often the premium for the single card w/dual GPUs is high enough that it would be cheaper to get another dual/triple or perhaps even quad slot motherboard, if you want THAT MANY GPUs.
  15. #90
    Jun 2009
    Parker, CO
    Finally got around to running some actual 3DMark tests with approved drivers so that the scores are now "official". When I first built my new rig, 3DMark 11 was having all kinds of issues with SLI, so I decided to wait on posting scores. Looks like now everything is running fine.
    3dMark 11 (Performance) - P12720
    http://3dmark.com/3dm11/1853612
    3DMark 11 (Extreme) - X4646
    http://3dmark.com/3dm11/1853919
    3dMark Vantage (Performance) - P44179
    http://3dmark.com/3dmv/3488671
    3dMark Vantage (High) - H36512
    http://3dmark.com/3dmv/3488690
    3dMark Vantage (Extreme) - X28347
    http://3dmark.com/3dmv/3488715
  16. #91
    Jun 2009
    Parker, CO
    Well... got some good news and some bad news. The bad news is that my EVGA X58 Classified has developed a bad USB Controller. So its RMA time (luckily EVGA's Lifetime Warranty rocks).
    The good news is that since I have to pull everything apart, I will be making some changes / upgrades to my system while I wait for the new Mobo to arrive. List of things I plan on changing.
    • Ordered a Sleeving Kit (among other things) from MurderMods
    • Got a Swiftech Apogee HD CPU Block to improve Cooling and flow
    • Got a WB for my RAM
    • Got new WB for my 9800GT (PhysX Card). The fan is the only loud part of my system, and I picked up an EK WB for it at Performance PCs for only $10.
    • Taking the two loops and making them one large loop with the two pumps working in series.
    • Getting a new Corsair Link fan/pump/lighting controller for software control of all those components.
    • Going to make and install an illuminated mid panel for some "Bling".
    I have also been laying out the new build in Google SketchUp to help me think through a few things. Not done yet but coming along nicely. Here is a pic of what I have so far.
    If anyone else wants to give SketchUp a shot, most of these components can be found in Google's 3D Warehouse. I did have to build a Swiftech Apogee HD from scratch since I couldn't find one I liked in Google's 3D Warehouse.
    Any ideas on how I might be able to improve the design?
  17. #92
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    Why not swap inlet with outlet on gpu blocks? This way both will shorten & you'd be able to get by without top 180deg twist.
  18. #93
    Jun 2009
    Parker, CO
    I may play with that idea once I start running the tubing. I would still have to do the 180d twist even if I swap them because of the clearance I have between the divider panel and the PSU. Its too tight to to a 90d turn (without kinking) if I come down directly on top of the PSU, so I have to use the 180 Rotary Adapter to extend the point where the tubing comes down through the panel just to the side of the PSU.
    I couldn't get it to work in SketchUP because of the clearance, but I will find out for sure once i try it with Tygon. Thanks for your input.
  19. #94
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    You can also put all three gpu-blocks on parallel, and then use both inlets on top of top block.
  20. #95
    Jul 2011
    San Diego
    I think the single loop is a good move with the 2 pumps in series. You could also consider the aquearo 5 rather than the corsair link. Personally I'd consider a case with more radiator support now that you're adding another GPU to the loop. I'll admit to being openly biased towards CaseLabs, but their new STH10 is like the 800D on steroids.
  21. #96
    Jun 2009
    Parker, CO
    Quote Originally Posted by stren View Post
    I am definitively going to use an Aquaero 5 along with 2 PowerAdjust components for the pumps. I did some more research on the Corsair Link, and its kind of a half baked product. Their support forum is flooded with customers that have had nothing but issues with the Link, and is isn't robust enough with its current configuration to handle very many fans, much less the wattage from a pump. Aquaero for me.
    I would love a CaseLabs case, but it isn't in the budget right now. The 800D will be fine for this build, but the next time I do a full system overhaul, I will probably go CaseLabs.
  22. #97
    Jun 2009
    Parker, CO
    This build is done. Starting a new thread here:
    Project Bright Panel: Corsair 800D, Liquid Cooled, Illuminated Mid Panel
Tags for this Thread
