    X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Page 1 of 3 123 LastLast
Results 1 to 25 of 75
Thread: Gpu-z
    Xtreme Mentor stasio's Avatar
    Jan 2008
    Malaysia
    Gpu-z
    GPU-Z v0.3.5
    * ATI Radeon HD 5870 (Cypress) fully supported (includes voltage monitoring)
    * Added or improved support for NVIDIA FX5500, 9400 GT, G73, GTS 240, GT 140, FX 1800, GT 120 (Apple), FX 380, FX 350, GTX 295 Single PCB, Quadro CX, FX 5800, FX 4800, FX 3800, GTX 180M, GTX 260M, FX 2700M, G 110M, GT 120M, GT 220M, FX 1700M, G 105M, MCP79MX
    * Added or improved support for ATI HD 4730, HD 4650 AGP, M92, M96, M98
    * Added clock reading for Intel i910, i915, i945, 946
    * Added support for DDR3 detection on G9x
    * Added monitoring support for RV7xx based mobile chips
    * Voltage controller "slaves" are now called "phases"
    * Added Intel Havendale detection
    * Fixed BIOS parsing on some newer HD 4870 cards
    * Added voltage monitoring support for MSI N275GTX Lightning
    Need a Gigabyte latest BIOS?
    Z370 AORUS Gaming 7,
    GA-Z97X-SOC Force ,Core i7-4790K @ 4.9 GHz
    GA-Z87X-UD3H ,Core i7-4770K @ 4.65 GHz
    G.Skill F3-2933C12D-8GTXDG @ 3100 (12-15-14-35-CR1) @1.66V
    2xSSD Corsair Force GS 128 (RAID 0), WD Caviar Black SATA3 1TB HDD,
    Evga GTS 450 SC, Gigabyte Superb 720W
    XSPC RayStorm D5 EX240 (Liquid Ultra)
    NZXT Phantom 630 Ultra Tower
    Win 7 SP1 x64;Win 10 x64
    Jan 2008
    Malaysia
    GPU-Z 0.3.6
    * Added Infotips, they can be turned off in the system menu
    * Added preliminary support for ATI Radeon HD 5900 (Hemlock), HD 5600 (Cedar), HD 5300 (Redwood)
    * Added full support for HD 5850, HD 5770, HD 5750
    * GPU-Z no longer crashes on ATI ULPS enabled CrossFire configurations
    * Fillrate Pixel, Fillrate Texel, Memory Bandwidth will now correctly recalculate when clocks change
    * Bus Interface, ATI shader count is now periodically refreshed
    * Added support for HD 5850 voltages
    * Second voltage on HD 5870 correctly named VDDCI
    * ATI clock reading code fixed
    * Fixed default clock reading on HD 5850
    * Added Mutex to avoid collisions on long I2C operations
    * Added basic detection for a lot of NVIDIA card fakes
    * Added detection for ATI FireGL V7600, M92, RS880
    * Added detection for NVIDIA GT 130, 9600 GE, Tesla C1060, G 220, GT 220, NVS 3100, GTS 160 M, NVS 160M, NVS 150M, G105M, GT 240M, G105M, G210M, G310M, ION LE
    * Fixed die size and transistor count on G72 M
    Jan 2008
    Malaysia
    GPU-Z.0.3.7
    - Added Infotips for sensors
    - Fixed crash when ATI ULPS CrossFire enabled
    - Added full support for ATI HD 5970 (Hemlock)
    - Added full support for NVIDIA GeForce GT 240 (GT215)
    - Added "ULPS active" note to CrossFire status when ULPS active
    - Fixed overclocks via CCC not showing correctly
    - Added checkboxes to show availability of CUDA, PhysX, OpenCL and DirectX Compute
    - Improved memory type detection for GT 216, GT 218
    - Added voltage monitoring support for HD 5770
    - Disconnected fan now shows correctly in sensors (when detectable via hardware)
    - Improved accuracy of ATI GPU load monitoring
    - Added detection for ATI RV380/RV530 cards relabeled to NVIDIA 9400/9500/9600 GT
    - Added support for NVIDIA 9300 SE, NVS450, GT 240, GTS 250M, G102M
    - Added support for Intel G41
    Jan 2008
    Malaysia
    GPU-Z 0.3.8
    * Added framework for translations in GPU-Z, to do that we need your help. Please go to tpu.me/forums/forumdisplay.php?f=72 to submit contributions in your language
    * Added sensors to monitor GPU load percentages on NVIDIA
    * Fixed startup on Windows 2000 (DLL not found)
    * Improved detection/added sensors for ATI M86
    * Fixed several NVAPI crashes
    * Fixed crash when PhysX not available
    * GPU-Z can now be set in its system menu to be always on top of other windows
    Jan 2008
    Malaysia
    GPU-Z 0.3.9
    * Added localized tooltips in the languages: AM, AR, BG, CN, DE, FA, FR, IT, PT, RS, RU, TR, UA. Default language is your system language, you can change this setting in the system menu of GPU-Z.
    * Added support for ATI HD 5830, HD 5770, HD 5750, HD 5670, HD 5570, HD 5450, HD 4860, HD 4750, Mobility HD 3430, M97, Mobile HD 5850, 5730, 5650, 5470 (Broadway, Madison and Park)
    * Added support for NVIDIA GeForce 6200A, GTS 250, 9800S, 205, 310, GT 320, GT 240, GTS 360M, 230M, 330M, 240M, G105M, Quadro NVS170M, G210M, GTS 250M, future MCP, more ION variants.
    * Added support for Intel GMA500, Clarkdale, Arrandale
    * Added detection for variants of NVIDIA NV41, G94, G98, ATI RV350, RV370, R480, RV515. Most of them used on fake cards relabeled to NVIDIA 9x00 series.
    * Improved default clock BIOS parsing on NVIDIA
    * Fix for incorrect default clocks on HD 5000 Series
    * Fixed incorrect real-time clock monitoring on some HD 5000 cards
    * Added more accurate real-time clock monitoring function for NVIDIA
    * Improved OpenCL detection on ATI R700, RV790, all HD 5000 cards
    * Added temp. monitoring support for some Intel IGPs
    * Improvements to CUDA detection
    * Removed memory chip input fields from VGA BIOS Upload
    Jan 2008
    Malaysia
    GPU-Z 0.4.0
    * Added support for NVIDIA GeForce GTX 470 and GTX 480
    * Added voltage monitoring for HD 5750, 5830, 5870 Lightning
    * Added support for Intel Pineview
    * Fixed double memory clock reading on NVIDIA w/ GDDR5 (real clock is now displayed)
    * Fixed rounding errors in RV7xx and Evergreen fan monitoring code
    * Added tooltip translations for Albanian and Chinese Traditional
    * Memory bandwidth calculation uses GB now instead of GiB
    * Added new hardware giveaway tab in cooperation with ASUS
    Mar 2007
    Test Labs
    Excellent! Thanks stasio!!
    Jan 2008
    Malaysia
    GPU-Z 0.4.1
    * Fixed an issue on all NVIDIA cards that would sometimes cause them to lose fan control when GPU-Z is running. Please don't run pre-0.4.1 and 0.4.1 at the same time, this might result in incorrect readings in the 0.4.1 window.
    * Fixed system crash on MSI HD 5830 TwinFrozr II
    * Validation upload now uses Unicode for entered name
    * Reverted memory bandwidth calculation introduced in last version. It introduces too much confusion, we will go with what all companies use in their marketing material, even though we believe it is not correct. Using power of 10 again now, 1 GB/s = 1,000,000,000 Bytes per Second.
    Jan 2008
    Malaysia
    Jan 2008
    Malaysia
    [GPU-Z Test Build] Fixes default clock detection on ATI
    http://forums.techpowerup.com/showth...25#post1846125
    Jan 2008
    Malaysia
    GPU-Z 0.4.3
    http://www.techpowerup.com/downloads/1798/mirrors.php
    Added full voltage controller monitoring for GeForce GTX 480
    Added real-time clock monitoring for GF100
    Added detection for vendor GALAXY
    Complete revamp of voltage controller architecture. Adds voltage monitoring for many ATI & NVIDIA cards and generic monitoring method for NVIDIA cards via driver.
    Added support for >4 GB memory on NVIDIA
    Fixed memory clock reading on some HD 5670 cards
    Fixed thermal sensor count on some ATI Evergreen models
    Fixed incorrect default clock reading on some ATI Evergreen models
    Added detection for NVIDIA GTX 465, GT 320M GT 335M, ION variant, GT 340, Tesla C2050, Tesla M2050, GTX 285M, GT 325M, Quadro FX 880M, Quadro FX 1800M
    Added detection for ATI HD 5570, Mobility 4550, Mobility 5870, HD 4250, HD 4290, FirePro V7750
    Added detection for Intel GMA 3150
    Added fix for ADT7473 coldbug (GTX 480) via commandline parameter /fixcoldbug
    Added OCP adjustment for CHL8266 (GTX 480). Use it via command line parameter /chl8266ocp without parameter to query, with numeric value seperated by space to set. This is a permanent change that will not be reverted by powering down the system.
    Added languages Hungarian and Spanish
    Updated languages French, Italian, Russian
    Jan 2008
    Malaysia
    GPU-Z 0.4.3.3
    http://www.fileden.com/files/2009/12...6817/GPU-Z.zip
    -fixes the "BIOS reading not supported" message on all ATI cards with 0.4.3
    -fixes a bluescreen crash on GeForce 8200/8300 devices related to voltage controller detection
    World Champion - IRONMODS
    Sep 2007
    Northern Japan
    Quote Originally Posted by stasio View Post
    Is this confirmed to be working? Is there any discussion on it somewhere?
    Quote Originally Posted by Massman
    My definition of 'efficient' is 'it does not suck monkeyballs'. Yes, I set bars low.
    [CENTER]The post counter is not an intelligence meter!
    MAX11L - "It's like a console...with the suck turned down and the awesome turned up" -tet5uo
    Heat Team IRONMODS
    Jan 2008
    Malaysia
    Quote Originally Posted by miahallen View Post
    Source:
    http://forums.techpowerup.com/forumdisplay.php?f=56
    Jan 2008
    Malaysia
    GPU-Z 0.4.4.0
    http://de1-dl.techpowerup.com/SysInf...PU-Z.0.4.4.exe
    -Added support for NVIDIA GeForce GTX 460, GT 330, GT 315, GT216 based ION
    -Added support for AMD HD 5670 (Juniper), Mobility HD 5430, Mobility 4200, Mobility 4100
    -Added PowerColor hardware giveaway
    -Added die size measurement for NVIDIA GF100
    -Added option to GPU-Z's system menu to show temperatures in °F
    -Fix for BIOS reading on ATI
    -Fixed decimal points in ADT7473 reading
    -Fixed crash on GeForce 8300 IGP
    -Added clock monitoring for RS780 variants
    -Improved clock monitoring for ATI R6xx architecture
    Jan 2008
    Malaysia
    [GPU-Z Test Build] Support for AMD Radeon HD 6950 & HD 6970
    http://forums.techpowerup.com/showthread.php?t=136218
    - Adds support for HD 6950 and HD 6970
    - Fixes fillrate rounding error on GTX 400 cards
    Jan 2008
    Malaysia
    [GPU-Z Test Build]
    http://forums.techpowerup.com/showthread.p...124#post2127124
    - Fixes a crash in OpenCL detection on NVIDIA cards, when the ATI Stream SDK is installed.
    For some reason AMD's driver still loads even though no ATI card is installed in the system.
    - Also fixed, rounding error when calculating Texture Fillrate on NVIDIA cards
  18. #18
    Jan 2008
    Malaysia
    GPU-Z 0.5.0
    http://www.techpowerup.com/downloads/1921/mirrors.php
    Added full support for Radeon HD 6950 and HD 6970
    Fixed TMU/Texture Fillrate rounding error on NVIDIA cards
    Improved voltage monitoring support for GTX 570
    Workaround for ATI OpenCL driver crashing GPU-Z on systems with NVIDIA cards
    Fixed crash when driver version could not be read
    Fixed crash when splash screen interrupted by message box
  19. #19
    Jan 2008
    Malaysia
    GPU-Z v0.5.1
    http://www.techpowerup.com/downloads/1930/mirrors.php
    * Added support for NVIDIA GTX 560 Ti, 480M, 485M
    * Added transistors and die size for 460M, 445M, 435M
    * Added release date for 6800 GT, 6600 GT, 6600, 6200, 8800 GTX, 8800 GTS, 8800 Ultra, 8600 GTS, 8500 GT, 8800 GS, 9600 GSO, 8800 GT, GTS 250, GT 440
    * Added preliminary support for AMD Zacate and Ontario APUs
    * Found a new way to disable NVIDIA's power limiter
    * Added support for GTX 570 and GTX 560 to power limit disable function, the parameter is now called /GTX500OCP
    * Fixed crash in sensors panel
    * Acer PCI vendor now using a shorter text that fits the field width
    * Added CHL8214 & CHL8226 support for AMD Barts and Cayman
    * Improved the automatic update check to run completely in the background and only appear when an update is available (manual update check is unchanged)
  20. #20
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    thanks stasio
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
  21. #21
    Oct 2005
    MA/NH
    still doesnt read 3d voltage correctly with 6900's
    Mpower Max | 4770k | H100 | 16gb Sammy 30nm 1866 | GTX780 SC | Xonar Essence Stx | BIC DV62si | ATH AD700 | 550d | AX850 | VG24QE | 840pro 256gb | 640black | 2tb | CherryReds | m60 | Func1030 |
    HEAT
  22. #22
    Jun 2004
    France
    Quote Originally Posted by Rattle View Post
    yeah that's too bad, you can only check it with AB atm
    2500K, 6970, Acer 245HQ
    E8400@3.85 + Vdroop P5K
  23. #23
    Jan 2008
    Malaysia
    GPU-Z v0.5.2
    http://www.techpowerup.com/downloads/1969/mirrors.php
    Added support for NVIDIA GT 440, GTX 550, GTX 560, GTX 570, GTX 590
    Added support for AMD HD 6990
    Added detection support for more Sandy Bridge IGPs
    Fixed ROP count on ATI Madison
    Improved OpenCL detection for ATI
    Added CHL8228 voltage controller support for Cayman Pro and XT
    Improved driver based voltage monitoring support for ATI cards
    Added startup parameter /card followed by the adapter index, starts with 1.
    Several crash and stability fixes
  24. #24
    Jan 2008
    Malaysia
    GPU-Z v0.5.3
    http://www.techpowerup.com/downloads/1978/mirrors.php
    Added support for AMD Radeon HD 6790, FirePro V5800
    Added support for GeForce GT 555M, GTX 540M, G315M, Quadro FX 600, FX 2800M, Quadro 4000
    Fixed GeForce GTX 590 release date
    Added support for voltage controllers VT1556, uP6266, uP6218
    Added VDDCI measurement on CHL8228 based ATI cards
    Added capability to show sensors in TechPowerUp OSD Server
    Fixed several crashes and resource leaks
  25. #25
    Jan 2008
    Malaysia
    GPU-Z 0.5.5
    http://us2-dl.techpowerup.com/SysInf...PU-Z.0.5.5.exe
    On multi-GPU systems, GPU-Z will remember the selected card from the selection dropdown
    Added full support for AMD A-Series Fusion processors
    Added detection for ASUS MARS II
    Fixed shader count detection for Blackcomb (mobile AMD Cayman)
    Improved BIOS version reading on NVIDIA
    Added support for NVIDIA GeForce GT 560 Ti OEM, GT 545, GT 530, GeForce GTX 580M, GT 555M, GeForce 520MX, GT 520M, 410M, 305M, Quadro 5000, Quadro 4000M, Quadro 400
    Added support for AMD HD 6290, Radeon E6760 & E4690, FirePro V8800, FirePro V3700, FirePro 2460 (FireMV)
    GPU-Z 0.5.5 - ASUS ROG Skin
    http://us2-dl.techpowerup.com/SysInf..._ROG_0.5.5.exe
