Howdy all, been some time since I last came here.
After reading about the "new" BIOS, I do not understand what the need for it was?
P08 or G25 it matters not. P08 is more stable, but both will work.
I am running at 1905 mhz (fsb) and 14/28 for the past several mos. w/o a single glitch with a 920 direct from intel replacement (my first cpu had a bad mem. controller). I have had the system to 2100mhz, but I found no need for this amount of speed. I have all voltages set to just before redline, and the usual preferd settings as well.
Perhaps it's your CPU memory combination, or perhaps it's the PSU that limits your particular FSB, I do not know for sure, but what I have found, is that when in SLI mode (2- 285 GTX extreams) you need very stable power- even with one card they are demanding. i7 is picky about memory and the power it receives.
I think many of you have one or two things, perhaps both going on, but I am not sure:
PSU issues and/or Memory issues (most likely cause)
I went thru 5 different memory module types and 3 PSU's before I was satisfied.
Antec 1000 watt PSU and Gskill Perfect Storm Memory kit.
And I dont use the fan cooler the memory came with- totally stable for well over 4 mos. 4GHz is pleanty fast for me- perhaps I should update my sig?
It works- Thats all I can say.
edited for spelling- sorry.
