Results 1 to 7 of 7
Thread: Overclocking Core i7 920 - P6TD Deluxe - Help
    Jan 2005
    Cheshire, UK
    Guys, I've just put together a new rig and I'm trying to get it tuned up.
    I've read that 4ghz should be pretty do-able for a 920 with the right system, but I'm really struggling to get the system stable. It that right?
    So heres what I've done so far:
    Turned off all energy saving, throttling, virtual tech (left HT and hardware prefetch on)
    Bclk @200 Multi @ 20x
    CPU=1.35v QPI=1.35v Mem=1.64v
    Dram is set low 1200mhz for now as anything above that causes the system to be unstable, even though my mem can do 2000mhz... I believe the cpu mem controller is the problem there?
    I have got the system so it will run Prime or OCCT stable @ 4ghz, but when I run 3DMark halfway through the second test, the whole system powers off (everything goes off for a few seconds) then the power comes back and the system starts to boot. I've tried different voltages but it persists, it also did it @ 3.8ghz so I get the feeling it may be the mem controller?
    I've been out the game for a while and its my first Core i7, so its possible I'm doing something wrong. Can anybody recommend me some base settings to start off on this MB?
    I'm worried that my temps are a bit hot as under load @ 4ghz -1.35v they are in the mid 80 degrees range. But I read that 4ghz is do-able on air so thought the little Corsair would be enough. Not sure now though?
    Can anyone offer any pointers on settings for the P6TD Deluxe? Specs are in sig by the way.
    Thank you.
    Intel Core i7 3820 / ASUS X79 Sabertooth
    Gskill 2133mhz Quad 16GB / Auzentech X-FI Forte
    Sapphire HD5970 OC 2GB
    4x 500GB Western Digital "Black Edition" (Raid5)
    Thermaltake ToughPower 1500w PSU / OCZ 1250W PSU
    Corsair H100
    CoolerMaster CM-690 / Windows 7 Pro 64bit
    Samsung T260HD 26" LCD / HDTV
    Aug 2009
    surabaya, east java indonesia
    maybe you should do more researching on this forum.
    this tread might help you :
    http://www.xtremesystems.org/forums/...d.php?t=210480
    in case you miss reading it.
    HTPC :
    i7 920 SLBEJ (#3909A179) "thats my past"
    this is my present & future rig :
    CPU : i5 3570K
    Mobo :Asus M5G,
    Vga : intel HD4000
    Mem : 2x CMZ8GX3M2A1600C8R (4x4gb stick)
    HSF : Noctua NH-D14
    ODD : DVD-RW Pio DVR 216L,
    Storage : WDC 500AALS x2 RAID 0+1,
    Case & PSU : Obsidian 650D + HX850w.
    Misc : Onkyo 605, Epos 12i, Epos M5, Epos M SUB, PSB B25.
    Panasonic 42G10S
    Aug 2009
    Midland, England
    Also worth trying this link for some infos..
    http://www.techspot.com/review/129-a...uxe/page4.html
    Core i7 4500MHz @ 1.33v
    Core i7 4200MHz @ 1.19v
    CPU cooling Prolimatech Megahalmes
    Motherboard P6T Deluxe OC/Palm
    Memory 6GB Corsair DDR3 Memory
    Graphics Card GTX 295
    Hard Drives 500GB Barracuda 7200RPM
    256GB SSD Read/Write 500/300 MB/s
    Power Supply Corsair TX 650W
    OS Win 7 Ultimate 64 Bit Retail
    Monitor 24" Dell 1680 x 1050
    May 2005
    Maybe it's your powersupply is my guess. I know 850watts is a lot, but you do pack a lot of hard drives and the gamexstream series wasn't the best.
    A+ Black Pearl
    GIGABYTE GA-EX58-UD5
    Intel i7 920 @ 4.1ghz | Apogee GTZ | Swiftech MCR320 | Liang D5 Vario |
    6gb Corsair XMS 1600
    Visiontek HD 4870
    3x 640gb AAKS Raid-0 Short-stroked 300gb
    Corsair TX750
    Olevia 42" 242TFHD 1080p
    Jan 2008
    Chicago, IL USA
    I just use Auto and the Bios will set everything to run up to 215 BClock.
    Hackintosh Lover
    Aug 2009
    Between London & Eastbourne, United Kingdom
    Hi Guys My friend just got a P6TD Dlx with his new core i7 which we are planning to overclock... He is got a waterblock and is using a 40 x 40 fan mounted on his NB as you have the option to do that now the reason he is got this mobo is cos he wants to OC so he choose this board cos we thought that it would be cool on the mobo but he is getting like 45 c on the MB temp and 50c on the Cpu according to prove 2, speed fan and bios so I think is too hot?? what do you guys think? not overclocking yet till I know the temps are safe...
    Why Not Try a Hackintosh for A Change?? Steps HERE!!
    Want to installing Mountain/Lion from a DVD or USB on you Apple PC?? Steps Here!
    Super Stable aKa 24/7
    Winners of EURO 08 | World Cup 10 | EURO 12
    Quote: Killin' Tube Kinks One Coil At A Time
    Hackintosh Lover
    "Dumb people" shouldn't use "Smart Phones"
    New Personal Wallpapers Selection
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    memory / motherboard compatibility issue???
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
