I was just thinking about you the other day Goddy. I knew you had this one in your sights. Congrats!
Yes, Yellowbeard, a tall rough man with a big yellow beard
Great job Goddy! - very impressed with you, as at your age I had not done anything close to what you have accomplished by now
I am very happy for you!
awesome stuff vivi. glad you finally got the record you were working so hard for
Vivi, what PL were you running at 650 FSB?
You could gain some more points in both lobby's with some good D9GTS running 7-6-5-16 and trfc at 45, my Rampage Extreme loved that.
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
il do that for sure next time
it was PL 9 iirc
my lobby high is particularly low this run, it was normally around 729 when not run 1st, and about 734 when run 1st
The test that's ran first always have the best fps apart from nature, that will not see any burst from being ran first at all.
Most gain i got from running drago low first.
PL9 at 655FSB is nice, i reckon PL8 is impossible or only possible with subzero cooling on the NB and lots of voltage but would give a nice boost if possible.
Hampti, yes i think i selected trfc 45 with memset, i can't really remember, it's quite a while ago since i played with the rex.
I found a screenie on my hdd that showed trfc 45, i've spend a lot of time tweaking memtimings back then and found this to be superfast, at least for SuperPi 32M so i think it's fast for 3D mark 01 too.
ooh! sorry im going to have to quote you on this one !
1997 when run 1st
1971 when run last,
the point difference was huge enough for me to run nature before all other tests. Look at kingpins score, his nature is also around 1970 something becuase he ran it last.
the lows you'll need a HUGE score bump to run them 1st, becuase its only x10 of the lows and x20 on the highs. so if you can get a HIGh running allot faster it would be good .
i like your 01 knowlege zues you are ripping it
Really?
Never noticed such behaviour, nature has always been the most consistant test of all for me.
I could also re-run it without the fps ever going down like lobby's or drago's.
Running drago low first could mean 40-50 fps difference, even though it's a low detail test so x10 points only it still came out best.
Since you have much more both cpu and gpu power things might be different though.
Nature is not the last test i run, car low is always the last. Re-running it till a good one pops up.
Nice job there Vivi
Nice 01 singe card WR kiddo Just saw it yesterday, been away for awhile.
Killer run Vivi
Great run champ!
Awesome chip as well
Very nice run ... Lucky guy !!!
Now , show us 2000FPS nature !
Congrats Vivi
