Thankyou very much!
I have managed to break the mousemat somehow i beleive it has shorted out inside, which is annoying since it is glued shut and i doubt i can get it apart without screwing it up. So it's back to the drawing board on that one
Thankyou very much!
That's what she said... :P
@oliverw Hi, very nicely done, normaly I don't like all those lighting stuff, but in your project I like them pretty much
24/7 Asus Rampage II Extreme |i7 920 /CoolerMaster V8|3x2Gb Elexir 1600Mhz |9800GTX+|640GB Seagate|Logitech Wave & MX400|GPS-650W
24/7 965 Extreme C0
NetGear ReadyNAS 4250: 3x500Gb Seagate
THankyou very much edimen
Great layout, look forward to seeing more updates
You are awesome.
Consider selling these.
How did you make the curvy tubes in sketchup though? And the components. They are very detailed.
E8400 @ 4.0 | ASUS P5Q-E P45 | 4GB Mushkin Redline DDR2-1000 | WD SE16 640GB | HD4870 ASUS Top | Antec 300 | Noctua & Thermalright Cool
Windows 7 Professional x64
Vista & Seven Tweaks, Tips, and Tutorials: http://www.vistax64.com/
Game's running choppy? See: http://www.tweakguides.com/
THe tubing in sketchup, there are some tutorials bit-tech.net about it. Check them out
Update #9
I am very pleased to announce my latest sponsor, AquaTuning!
They are going to be my watercooling sponsors. Watercooled-pcs have lost contact. I am not sure what has happened. THanks so much to Pascal for bearing with me!
My AC Ryan sponsorship has arrived! Yay for awesome brushed aluminium!
Slimline CD Drive
USB backplate
More CAD work is done.
Black line = cut
Green = reference
Red = engrave
This is the bottom plate for the slimline drive. The screws are so dam small for the drive i have decided to glue an acrylic plate to the bottom of it and then screw into the plate.
The aluminium base plate. The circular things are the feet, top left block is the psu, top right small block is the fan and fan mount, middle bottom box is the cd drive and bottom right is the HDD bay. You can see the amazing clearance of 1mm between the hdd bay and the PSU!
Fan mount
HDD Bay. There are 2 of each of the bottom pieces
This is the motherboard tray. I promise all the crazy holes will make sense in the end!
Finally, the masterpiece is unveiled! The completely redesigned fan controller and ccfl/led power board. This is the control hub of all the lighting. The board measures 8cm x 4cm.
So not a very big update. I have ordered the acrylic, should be here tomorrow. Then i can cut up some acrylic!
Oh wait i nearly forgot something...
Custom made waterblock for the 9300 chipset FTW! Thanks so much to duniek, can't wait to get some money so i can pay him and get it shipped to me!
Ok that really is everything now!
Very nice build.
I also have a question about your keyboard. I have the Tarantula and deathadder lover them both just with my key lit up. I was thinking of selling this one and getting the same one as you, but I heard the touch part of the board can be kind of picky and such. Have you ran into any problems with it so far?
~ Little Slice of Heaven ~
Lian Li PC-A05NB w/ Gentle Typhoons
Core i7 860 @ 3gHz w/ Thor's Hammer
eVGA P55 SLI
8GB RAM
Gigabyte 7970
Corsair HX850
OZC Vertex3 SSD 240GB
Yes i have had issues. I can't get the media keys to work any more. The volume and backlighting ones work fine, but the media ones don't. I may rma it.
eVGA P55 SLI
8GB RAM
Gigabyte 7970
Corsair HX850
The tarantula by razer is a nice keyboard and doesn't have the touch bits. I don't think i would get somethign with gimmicky touch sensitive buttons again. I'm addicted to backlit keys now though! It is so good when gaming. You can turn all the lights off and get properly involved with it all.
wow - great sketchup skills
awesome, keep posting man !
BTTB - Gigabyte Z87X-OC - WCed I7 4770k - 2x8gb Ballistix 1600mhz - Zotac GTX 780
Asus Xonar Pheobus - OS -> Toshiba Q 256gb - Games -> 2x Agility 4 256gb Raid0
Corsair HX850 - Tecnofront HWD BenchTable - Asus VE278Q 5760x1080
Serveur - Asus Z77m PRO - 2500K - NH-C12P - 4x4gb G.Skill Ares 1600mhz
Agility 4 128gb - Corsair CX430M - 1TB Black - 2TB green - 2TB Red
KatPat - Gigabyte 990FXA-UD3 - FX-8320 - PH-TC14CS - 2x4gb Viper 1600mhz - GTS 450
Samsung Evo 120gb - Corsair HX750 - Bitfenix Survivor White - Asus VE247H
Very nice!!!
What CAD system are you using? Solidworks? Did you start this CAD drawing/assembly from scratch, or were you able to somehow get CAD models for some of the stuff?
Thanks,
Ed
920 DO @ 4200Mhz 210X20 1.35Vcore HT on, everything except Turbo enabled!!
MCP600--Dangerden heatercore--Apogee GTZ--Weapon heatercore back to the pump with a T-line. All fans are 120mm Sanyo Denki San ace's
Gigabyte GA-X58A-UD3R, 6GB Corsair XMS3 1680Mhz 8-8-8-24 1.666V, QPI-3780Mhz, NB-3360Mhz
2 Evga 460 Superclocked EE's in SLI
BFG EX1200Watt PSU
Windows 7 Ultimate 64bit
5.5TB Internal HD space!!
2 Seagate external HD's totalling 2.5TB's
HAF 932
2600K @ 4.5GHZ 1.280Vcore
16GB Gskill Ripjaws 1600Mhz 8-8-8-24-2T 1.5V
1 Evga 570 SC, 1 Evga 260 SC (Physics)
PCP&C 750Watt Mk II PSU
Windows 7 Pro 64bit
2x120GB Gskill Sniper SSD RAID0
2x1.5TB WD Black Sata III RAID0
HAF X
Heatware
Very nice I am impressed! I would also like to know the above question.
I can't wait for your finished project
CPU:Q6600 G0 @ 3.825
Motherboard:Asus P5E X38
Memory:2x2GB OCZ Reapers DDR2 1066
Graphics Card:Asus 4850
Hard Drive:2xSegate 500gb 32MB Cache raid0
Power Supply:Xion 800W
Case:3DAurora
CPU cooling: D-tek Fuzion V2 (Quad insert removed)
GPU cooling: mcw60
Monitor:24" LG
Hi Thanks for the comments!
I used Google Sketchup PRO for everything. I found models for the motherboard, rad, gpu and ram and a few other things. The rest i made myself.
I should have an update out in a few days, be it fairly small
Case:3DAurora
GPU cooling: mcw60
Monitor:24" LG
Update #10
Left side acrylic panel cut and engraved! Aqua tuning sponsor's logo.
eBuyer logo etched out
Holes for the GPU fan. Around 180 holes!
More shots of the engraving
The entire left side panel. There is a version of this without the sponsorship logos so when the time comes i can submit it for MDPC (MDPC doesn't take PCs with sponsorship logos on).
CD drive base. This will be glued onto the cd drive (please don't kill me! I swear it is the only way for this to work!)
Right hand acrylic panel
Top acrylic panel with holes for rad and fillport.
Motherboard tray (i told you it was complicated!)
Here we have some orange UV anti kink coils. These things are great!
SATA laptop optical. This thing actually isn't the right cable, and it annoys me greatly, since it took 3 weeks to ship from hong kong! I have no idea what it is, but it isn't a normal sata optical.
4gb Crucial Ballistix Tracer 800mhz - £20 from someone on OCN!
It is finally here! My nickel-plated-custom-made-insanely-awesome 9300 chipset waterblock for the zotac 9300-itx wifi motherboard! Thanks Duniek! The craftsmanship is stunning...
Perfect base
Latching vandal switch (blue LED)
Pins for...
24 pin and 4 pin connector
Approves!
Some mesh from MNPCtech! Thanks Bill! http://www.mnpctech.com/moddersmesh.html
Hard drive bay. Not glued yet
Test fit of CD drive, cd drive base and hard drive bay
This is the design for the aluminium front surround. The 2 larger holes are the power switch and the light switch, the two smaller ones are fan controller potentiometers. The slot hole near the bottom is for the CD drive. Those funky designs wrap around the components
And finally, V4 of the fan controller! This now measures 83mm x 33mm and is gonna be awesome! I have ordered all the parts for it. I will start PCB manufacture maybe on friday.
Thanks for reading!
waiiiiiiiting for more !
You shall have more, maybe after the weekend
Ok i lied, have more now!
Update #11
My watercooling sponsorship arrived!
Thankyou so much to aquatuning! http://www.aquatuning.co.uk . Thanks especially to Pascal for putting up with me!
Here we go...
Black Ice GT120 lite with 45 degree compression fittings on. These things are so cool, they rotate!
More rad
Fractal Design 60mm fan
Cable ties + bases
Fillport with compression fitting
Low profile straight compression fittings
45 Degree rotary compression fittings
90 degree rotary compression fitting
Mah lovely black nickel plated compression fittings!
Bitspower T-block with compression fittings
Couple of tube clamps for the block
Momentary dot-illuminated vandal switch
Primochill UV Pink Dye Bomb
Distilled water
2 pairs of UV cathodes
Tygon 3/8" ID 1/2" OD tubing
Scythe S-Flex 1600rpm
Apogee drive top
3/8" barbs on the drive
This thing is so cool!
45 and 90 degree fittings on my custom 9300-itx waterblock
Shipment from Rapid is here, bringing with it a multitude of goodness in electronics!
Some cheap sleeve and heatshrink
500 resistors (i'm not joking!)
2 and 3 pin molex housings/headers
Transistor
Capacitor
MIC502 chip. These things are SO TINY!
No that is not a giant key!
Capacitors, diodes and potentiometers
Put some dye in my distilled water. ooooo!
Test fitted the top of the PC (fan grill, acrylic, rad, fan). The rad is literally just as far over as it can possibly go. Another 0.5mm and it would be out of the edge!
From the top
Layers
Fillport in place
Fan/rad assembly
Removed the 9300 heatsink from the motherboard. Messy thermal paste underneath!
Installed duniek's waterblock
Installed the Apogee Drive! It just fits!
How close the parts are!
And finally, PWM Controller V5! I think it is done! Wait, no, just seen a problem! Time for V6...
Wow! Thanks for the update
[CENTER]The post counter is not an intelligence meter!Originally Posted by Massman
MAX11L - "It's like a console...with the suck turned down and the awesome turned up" -tet5uo
Heat Team IRONMODS
