Page 3 of 10 FirstFirst 123456 ... LastLast
Results 51 to 75 of 250
Thread: Bloodrage P09 bios
  1. #51
    Technician
    Jun 2002
    Merseyside, UK
    I could only get one corner of one spreader to lift - it looked like D9GTS but couldve been GTR. These are old stock too - got them in clearnace 50% off .
    Also have 3gb ocz gold 1600 which is single sided D9JNL. Good cheap kit.
    Try www.memoryc.com - they ship internationally, carry a huge range and are really helpful.
  2. #52
    Feb 2009
    Quote Originally Posted by PiLsY View Post
    Just so you guys are aware ive found turbo works at 18x multiplier. I can boot at 18x (confirmed by post screen) and as soon as windows launches im at 21x.
    It let me do this: http://valid.canardpc.com/show_oc.php?id=677022
    18x is my best multi for fsb clocking, and it looks like i may be able to max out the cpu at around that speed .
    Not sure whether to go for stabilising this now or to leave that for the end and sort my ram and uncore out now. Running prime atm so ive got 10 misn or so to decide :p.
    Tried your little trick and got this
    http://i552.photobucket.com/albums/j...t/oggie2-1.jpg
  3. #53
    I am Xtreme
    Dec 2008
    France
    Quote Originally Posted by oggie View Post
    Very nice! Now get it stable.
    Donate to XS forums
  4. #54
    Nov 2008
    Heart of Europe
    Heh my Cellshocks and those now are from memoryc. I know them.. but they are definetly not cheap.. choose them just cause they had Cellshocks I wanted..
    i7 930 D0 - 4,2 GHz + Megashadow
    3x4GB Crucial 1600MHz CL8
    Foxconn Bloodrage rev. 1.1 - P09
    MSI HAWK N760
    Crucial M500 240GB SSD
    SeaGate ES.2 1TB + 1TB External SeaGate
    Corsair HX 850W (its GOLD man!)
    ASUS STX + Sennheiser HD 555 (tape mod)
    Old-new camera so some new pics will be there.. My Flickr My 500px.com My Tumblr
  5. #55
    Feb 2009
    Quote Originally Posted by zalbard View Post
    I wish
  6. #56
    Technician
    Jun 2002
    Merseyside, UK
    Works with d0 too then - glad it helped you oggie .
    Having difficulty with uncore at high bclk. Im stable at 21 x 210 using 6x mem and 12 x uncore. However get bsod's at 18 x uncore and freezes at 20 x uncore. Tried vdimm up to 2v - no go.
    Anyone tried messing with the qpi and cpu latency and drive settings with any success? Not tried ioh or cpu clock delays either.
    I may just be at the limit for my cooling to be fair. I've been weighing up a spare Alphacool 360mm XT I did an epoxy repair on. I reckon I can squeeze it in the front of my case. Likely to take months tho as itll need a few days for a full rebuild and case modding.
    Managed 3dmark at 21 x 212 tho. I'll have to do a graphics overclock and get a score published. 26k in '06 looks feasible. Not tried vantage yet.
  7. #57
    Feb 2009
    You tried increasing IHO v to 1.30 ? It normaly helps with higher speeds
  8. #58
    Apr 2006
    Non of the links for PO9 are working for me, cant find this bios anywhere, if someone has a new link could you please post it.
    TIA
    Intel Core i7 920 2.66ghz @ 4.3ghz HT Enabled, core @ 1.34v, VTT @ 1.28v, NB @ 1.30v (212 x 21) Batch No: 3910A369
    6gb (3x2gb) G.Skill RipJawsX DDR3 17000C9 2133MHz @ 1640mhz 8-8-8-24-1T
    Gigabyte G1.Sniper Rev 1.0 @ 205fsb Beta Bios
    1 x OCZ Agility 3 120gb SSD, AHCI
    1 x Western Digital 500gb SATAIII 16mb Cache HDD, AHCI
    Sony DVD +/- R/RW/RAM x22 Dual Layer, AHCI
    2 x Saphire ATI Radeon R9 270 2gb (Crossfire)
    Gigabyte Odin 850w Modular PSU (Software Controlled)
    EK Supreme HF Copper LGA1366, Laing D5 Pump, 2 x 240mm Radiator & 120mm Radiator
    Cooler Master HAF XB LAN Box
    Windows Se7en Pro x64 bit
  9. #59
    Technician
    Jun 2002
    Merseyside, UK
    The link Lord Trident put up in the original post is working fine for me? If you pm me your email address ill email you the bios .
    Im already at IOH 1.36 (1.398v dmm) - I think I can drop this a lot though, maybe 1.25 or so. It may be one of the southbridge voltages - its less stable when i put them back to default. These things need so much tweaking to max out...just cos you find the max of everything separately doesnt mean itll all go together...
  10. #60
    Apr 2006
    Thanks, PMed you.
    The link on the bios archieve page is taking me to some corporate web site, and the link at the beginning of this thread is taking me to a :banana::banana::banana::banana: page, LOL lucky for some if you like that, dont get me wrong I do, but not when its a bios im after.
  11. #61
    Nov 2008
    Heart of Europe
    I´m afraid problem is on your side of cable.. your PC is adwared, wormed, malwared or god know what.. try Avast + Spybot SD.
    MSI HAWK N760
  12. #62
    Nov 2008
    Heart of Europe
    Setting CPU delay to 200ps helps a bit for me. CPU and QPI latency tried at maximum 250 and 240.. helped me with higher CPU freq to be more stable.
    About uncore, well anything near 3.8GHz uncore and more, requires lot of VTT if you are OCing whole system.. little bit less, if you push just uncore. Limit is usually around 4GHz.. (I´ve managed that semi-stable).
    20x210 = 4,2GHz which is way too high for uncore to work. Good freq is around 3,6 GHz, thats where I have it for 24/7.
    MSI HAWK N760
  13. #63
    One-Eyed Killing Machine
    Sep 2006
    Inside a pot
    The BloodRage Archive links won't work for a few hours as I... forgot to renew my domain names! ( well done! )
    Depending on the update status of your ISP's DNS server you'll be able to use the BloodRage BIOS Archive in 2 - 24 hours.
    Coding 24/7... Limited forums/PMs time.
    -Justice isn't blind, Justice is ashamed.
    Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Crystal Chen, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Dan Snyder, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Mike Clements, Alex Ruedinger, Oliver Baltuch, Korinna Dieck, Steffen Eisentein, Francois Piednoel, Tanja Markovic, Cyril Pelupessy (R.I.P. ), Juan J. Guerrero
  14. #64
    Technician
    Jun 2002
    Merseyside, UK
    Doh!!
    I'll email you the bios in 10 mins or so dude .
    Weird thing with the uncore is that I can get into windows and run a few loops of linx at 4500mhz+, I just get a bsod after 10 mins or so at load with it any higher than 3950. Clock interrupt on secondary processor blah blah.
    The 8x ram multi isnt really an option with cas 7 not working, so im stuck at 1200 - 1300mhz and 6-6-6-14-1t. Will try memset to get a few 5's in there - board wont post with any timings set to 5 in bios.
    Could still be heat buildup - afterall my loop is overloaded really for linx testing at 4.3ghz+. Fine for prime etc, just linx. 90+ cpu temp in linx..
  15. #65
    Nov 2008
    Heart of Europe
    Doh!!
    You mean CPU freq or Uncore freq? I meant uncore before.
    MSI HAWK N760
  16. #66
    Sep 2006
    Inside a pot
    BloodRage BIOS P09 @ RapidShare
    [ BenchZone's Download Repository should be back online for most of you now as well ]
  17. #67
    Apr 2006
    nice one guy's, gonna flash and have a play about with this one.
    Can I just use the award flash utility that comes with P08 to flash P09 ?
  18. #68
    Feb 2009
    You can use fox live update
  19. #69
    Apr 2006
    hate using windows based flashing utilities, im using Windows 7 x64bit, ever since one went wrong for me in Vista x64 which apparently supported it, just stopped responding, nothing left to do but restart, and never came back on.
  20. #70
    Mar 2009
    Sunny South Florida
    Quote Originally Posted by Seanie's Show View Post
    Hey I used the Fox Live this inside of windows 7 64 rtm and worked without any issues.
    Intel System
    CPU: Intel i7 990x ES @ 4.2GHz 24/7 still kicking!
    Mobo: Foxconn BloodRage X58 P11 Bios
    Ram: Corsair Dominator 12GB DDR3
    Water Cooling: Apogee XT, MCP655-B pump, MCR220 radiator, XSPC 5.25" Bay reservoir
    Videocard: EVGA Nvidia FTW+ GTX 1060 6GB
    OS HDD: Samsung 950 Pro 512 MB M.2
    Strorage HDD: W.D. VelociRaptor 300GB
    Storage HDD: W.D. 500GB
    PSU: Enermax Evo Galaxy 1250 Watt
    Case: Cooler Master Cosmos S
    Roms: Lite On DVD Burner
    Roms: Asus Bluray Burner
    OS: Windows 7 Ultimate 64-bit
  21. #71
    May 2009
    Well I did it. I updated to P09 from G25 I decided to start from square one after a full CMOS clear just to be sure no remnant stuff was left behind. Right now I'm making my BCLK stable at 215 as I'm going to shoot for 4.5GHz with HT on and see if P09 is going to treat me and my D0 well
    I have the CPU running at 3GHz with 1,051 Vcore loaded which I know is stable to eliminate that variable. BCLK related settings:
    BCLK: 215
    PCIe: 102
    QPI: 18x
    Uncorex: 18x (3,875GHz)
    Memory: 8x (1722MHz)
    IOH: 1.24v
    Vtt: 1.312v (+120mV)
    I just ran LinX 3 passes and it succeeded - initial stability seems ok. Now going to let Prime Blend run for a while and see how that holds up.. If that works out well, I'll keep dropping Vtt to try to go as low as possible with it - I know I am going to have to up that again once I am going to speed up the cores (higher core = more intense L3 cache / IMC usage). So far it's all looking good!
    i7 920 D0 4.2Ghz HT 1.36v|OCZ Blade 1644MHz 6-6-6-16|Bloodrage
    HK3.0|Feser 360|MCP655|MM U2-UFO
    Club3D 4870x2|Promise EX4650 RAID5
  22. #72
    Apr 2006
    I did the same thing magicbox, updated to P09, then did a complete clear cmos and clean setup of the bios, I cant see that anything new has been added to this bios since G25, just a couple of options have been moved around.
    Ran a straight set of 20 passes on Linx 6.2.0 on exactly the same settings I was using in both G25 and P06.
    CPU = 4,202mhz (200x21) 1.28v
    MEM = 1600mhz 1.65v
    Blk = 200
    I remember one of you guys talking about finding a bug in this bios already and was waiting to see if anyone else picked up on it, well what ive picked up on so far is this bios is way slower than the previous one I was using (P06), Windows seems to take longer to boot, POST seems to take longer and also the initial bios screen seems to take longer to pass, maybe its just me being picky.
    One other problem ive discovered, is once in Windows, not all of my start-up items, ................well started, even important things like the audio driver, I had to restart a couple of times for this to launch, and even then my ATI control panel never started, I just ended up manually launching that.
    Im gonna try a format and see if that cures some of the problems, as my system is way past due for one, all this tweaking and crashing, temp instability damages the Windows install.
    http://img83.imageshack.us/img83/3722/captureual.jpg
  23. #73
    May 2009
    You have any clock delays set? Either CPU or IOH skew? Setting those to a 'wrong' value can have that effect. I leave those to the defaults as that seems to be the most stable anyways, these settings come into play when you want to push your BCLK hard, which 200 isn't.
    P09 hasn't given me any problems so far. In fact, I'm now running 4400MHz stable. 4500 is just too much for my D0. I could get it stable but it would take excessive voltage, over 1.47 and that's too much for my liking (even though temps fully loaded stay below 90 which I consider the absolute max for 5 minutes stresstesting). From then on I just 'stresstest' with gaming. No excessive temps and if they BSOD, I just add a notch Vcore untill crashes go away. 4400MHz however I can still load for an extended period of time without temps going crazy.
  24. #74
    Apr 2006
    no I leave the skew's at default too, if blk 200 isnt pushing hard, then why the hell can i get past it, no matter what I do, it just wont pass it, I got to 202 earlier but that was by bumping the mem voltage upto 1.7v and the NB upto 1.3v, it wouldnt go any further than that.
    I have +70 on the cpu volts giving me 1.28v but im scared to put anymore through it as my temps hit 85oC now, accoring to realtemp.
    see my bios settings here, they are exactly the same for P09 too as they were for P06:
    http://www.xtremesystems.org/forums/...5&postcount=53
  25. #75
    Mar 2009
    Sunny South Florida
    I haven't installed P09 yet. Running G25 using Seanie'sShow's exact settings and stable as hell. My core is almost off the same batch. My temps never passed 75c and I live in Hot South Florida near Miami... I did use TX-3. Maybe that might help????
    Intel System
