am running
q9450 currently at 3.2ghz
gigabyte EP45-DS3P
2x2gb kingston p8500C5
non overclocked asus 260gtx.
Its stable at 3.2ghz. Any higher, even 20fsb higher and it boots fine but i get no output from gfx card. Have locked pci bus to 100.
Would like 3.8ghz if possible! as i had an e5200 at 3.8ghz before it!
Cooler is one of those big noctua things, sexy as hell!
And a question.
is it safe to turn off the rear fan on my antec 900, and turn on the big 200mm one instead ? This creates less noise and apparently moves more air, also the exhausted air from the push-pull noctua points at the 200mm.
thanks
