We all know that machining those intracet designs in the base is really tough.
HAve you guys ever heard of copper clay?
I have a friend that makes jewelry and she has this stuff called "copper clay".
I was asking her about it and this is how it works:
The copper clay has some kind of other filler in it that makes it a clay so you can bend and engrave it.
Once you make your design with the clay you put it in a kiln and then all the filler in it burns out so you are left with a copper base that can have some awsome intrcet designs.
So do you guys think this stuff would work for making pots?
It is pretty expensive but if you only use it for the base it would be awsome. Rio grand sells it for like $10 every 100g's
