Results 1 to 3 of 3
Thread: Crossfire Fan Problems?
    Jul 2009
    Gatech atm
    When i enable Overdrive in the CCC, i can control the fan of one video card, but the second video card's fan spins at a constant 50~% judging by noise, is there a way for me to control both fans or should i just ditch CCC altogether.
    Note: I'm using 2 sapphire 4870 512 mb, reference boards with stock full cover plate and fan paired with liquid cooling for the die.
    Nov 2007
    San Diego, CA
    I used to have HD4870 in CrossFire and there was a guide that show how to manually adjust the fan speed for both GPUs. I thought the latest Cat should fix it but anyway, you might wanna give it a try:
    1. Turn ON Overdrive in the CCC and leave the clocks speeds at default.
    2. Make a profile in the CCC (this will be your fan speed profile, you can have more than one)
    3. Find and EDIT (via rightclick) the "C:\Users\USERNAME\AppData\Local\ATI\ACE\PROFILENA ME.XML" File
    Find:
    <Feature name="FanSpeedAlgorithm_0">
    <Property name="FanSpeedAlgorithm" value="Automatic" />
    </Feature>
    <Feature name="FanSpeedRPMTarget_0">
    <Property name="Want" value="0" />
    </Feature>
    <Feature name="FanSpeedPercentTarget_0">
    <Property name="Want" value="XX" />
    4. Change:
    Automatic to Manual
    The FanSpeedPercentTarget value (shown as XX) to the percentage you wish to use.
    "FanSpeedAlgorithm_0"....... is the 1st video card.
    "FanSpeedAlgorithm_1"....... is the 2nd video card.
    EXAMPLE:
    <Property name="FanSpeedAlgorithm" value="Manual" />
    </Feature>
    </Feature>
    <Property name="Want" value="65" />
    and then scroll down and the _1:
    <Feature name="FanSpeedAlgorithm_1">
    </Feature>
    <Feature name="FanSpeedRPMTarget_1">
    </Feature>
    <Feature name="FanSpeedPercentTarget_1">
    5. Save the XML file.
    6. Activate your profile(s) in CCC.
    CPU: Core i7-2600K@4.8Ghz Mobo: Asus Sabertooth P67 Case: Corsair 700D w/ 800D window
    CPU Cooler:
    Corsair H70 w/ 2 GTs AP-15 GPU: 2xGigabyte GTX 670 WindForce OC SLI
    RAM: 2x8GB G.Skill Ripjaws PSU: Corsair AX850W Sound card: Asus Xonar DX + Fiio E9
    HDD:
    Crucial M4 128GB + 4TB HDD Display: 3x30" Dell UltraSharp 3007WFP-HC
    Speakers: Logitech Z-5500 Headphone: Sennheiser HD650
    Jul 2009
    Gatech atm
    Thanks it worked, nice n cool and quite now
