gtx280 sli + vista64 + nvidia 190.62 + bionc 6.10.5 = computation errors
Distributed Computing: Making the world a better place, one work-unit at a time.
http://www.worldcommunitygrid.org/index.jsp
wcg/gpugrid/sli setup = i7 920 + gtx280 sli + vista64 + nvidia 190.62 + bionc 6.10.5
cpu settings at 80% of processors and 80% cpu time. I now have 2 tasks running, each one running on 0.14 cpu and 1.0 gpu; while 8 wcg tasks are running. estimated time for the 2 gpugrid tasks is around 2.5 hours. seems to have fixed the computation errors, should have figured this one out sooner. any advice on these settings? Thanks
Edit: I can tell from watching the cpu/gpu temps the tasks are cycling on and off quite a bit. wcg seems to be active only about 1/2 the time. is this a resource share setting issue? right now wcg and gpugrid are set at 50% each. advice on this setting? Thanks
Edit: estimated time to completion for gpu tasks has risen to 3+ hours. I know these estimates should not be given too much credit, I will wait and see what happens.
Edit: computation errors
can you try out 1 vid card out and disconnect the other card to see if it completes a work unit on its own , just curious if you can complete a work unit on 1 card.after try the other card out so we can say its not the vidcards if both work, i know its a pain ars to pull cards with them set up in water cooling but we should rule out the cards first.
great idea. (hehe duh on me) I will try that and report back. Thanks.
MY GTX 295 works fine on gpu 1 but gpu 2 errors out. GPU 2 worked fine on folding and works fine in games.
Server: Core I3 530 , 4GB of dd3 1066, GIGABYTE H55M-UD2H, Highpoint Rocketraid 3510 and Areca ARC-1220 with a few arrays totaling 11TB of storage
Wifes: Phenom 2 940, 4gb of ddr2 1066, 785g mb, PNY 8800 gt, Hitachi 2tb, Coolermaster Cosmos, 2x 22" monitors Windows 7 Pro 64
HTPC/Gamer: Core I-7 920 @ 3.8, 6gb of ddr3 1600, Gigabyte X58-UD5, MSI GTX 480, Intel 80 GB SSD, SuperTalent 120 GB SSD, Thermaltake DH-103, Windows 7 64 bit 52" JVC(Supporting cast of Jamo speakers and Cambridge Audio Azur 640r receiver)
Mine: 4x AMD 8356, 16 GB of ddr2 533 ecc, Tyan Thunder S4985G3NR, EVGA GTX 275 FTW, Intel 40 gb SSD, Ubuntu 10.04, Klipsch Promedia 2.1, 27" LG monitor
Have you tried a later boinc
My Biggest Fear Is When I die, My Wife Sells All My Stuff For What I Told Her I Paid For It.79 SB threads and 32 IB Threads across 4 rigs 111 threads Crunching!!
It looks like 6.10.13 is working.
Keep us posted on this ...good news though so far
computation errors. the video driver "stops responding" (as per the vista error msg) for a split second, creates the computation error, stops the gpugrid wu. been trying different combos of vid drivers and bionc client. now I must try shadowwind's suggestion of physically 1 card at a time
im hoping that works for you PB, that galaxy PSU you got what is it rated at?
i had a similar experience with a psu going bad just moving my mouse would cause it to error out, it may sound weird to you but when i changed it out things started working.so im thinking 1 card should work.i got my fingers crossed things will work out.
its an enermax galaxy 1000W. the cards run fine in 3+ hour overclocked sli gaming sessions. the error usually happens in the first 15 minutes of a wu. I thought it was the bionc screensaver kicking in, disabled all screensavers and power management stuff, not the problem. It's not temps, low volts to the gpu's, or overclocked settings (mobo or vid), tried those. I'll keep digging...
Edit: I keep wondering if there is some kind of throttling going on with the vid cards. I've been researching the cards and looking through rivatuner, can't find anything
ok. bionc 6.6.41 + nvidia 191.07 + vista64 + 2x gtx280 + sli enabled = over 1 hour of gpugrid crunching with zero errors (while also crunching wcg). since all my previous problems were popping up in the first 15 -20 minutes, I think I got it. wooters
Errors. F*ck it.
