Results 1 to 8 of 8
Thread: 9800gx2 problem.
    I am Xtreme
    Dec 2001
    S.W, Florida
    9800gx2 problem.
    I picked up a TPower I45 I started out with my 9800gx2 installed with a E6600. When I tried to install os the system would show hdd, and start install process. It would get to blue screen that says starting windows setup and hang there, I tried switching hdd, dvdrom. Same thing everytime. I pulled it and moved it to another bench, just for yje hell of it I installed a 7600gt and it went into install process and completed. Got everything set up and ready to start installing updates. Pulled 7600gt and installed the 9800gx2 and it will not go into windows. What could it be?
    Dec 2003
    At work
    How big is your power supply?
    Server: HP Proliant ML370 G6, 2x Xeon X5690, 144GB ECC Registered, 8x OCZ Vertex 3 MAX IOPS 240GB on LSi 9265-8i (RAID 0), 12x Seagate Constellation ES.2 3TB SAS on LSi 9280-24i4e (RAID 6) and dual 1200W redundant power supplies.
    Gamer: Intel Core i7 6950X@4.2GHz, Rampage Edition 10, 128GB (8x16GB) Corsair Dominator Platinum 2800MHz, 2x NVidia Titan X (Pascal), Corsair H110i, Vengeance C70 w/Corsair AX1500i, Intel P3700 2TB (boot), Samsung SM961 1TB (Games), 2x Samsung PM1725 6.4TB (11.64TB usable) Windows Software RAID 0 (local storage).
    Beater: Xeon E5-1680 V3, NCase M1, ASRock X99-iTX/ac, 2x32GB Crucial 2400MHz RDIMMs, eVGA Titan X (Maxwell), Samsung 950 Pro 512GB, Corsair SF600, Asetek 92mm AIO water cooler.
    Server/workstation: 2x Xeon E5-2687W V2, Asus Z9PE-D8, 256GB 1866MHz Samsung LRDIMMs (8x32GB), eVGA Titan X (Maxwell), 2x Intel S3610 1.6TB SSD, Corsair AX1500i, Chenbro SR10769, Intel P3700 2TB.
    Thanks for the help (or lack thereof) in resolving my P3700 issue, FUGGER...
    I am Xtreme
    Dec 2001
    S.W, Florida
    Quote Originally Posted by lutjens View Post
    CM1000w, before switching mobo. This psu and card were in a I7 setup and performed perfectly.
    Xtreme Legend
    Mar 2008
    Plymouth (UK)
    Which driver? I've had trouble with drivers since 182.08 with symptoms like black screen until I swapped to the secondary side and found everything there I have two of these and even during one boot on 190.38 the start screen was on the secondary slot and that in a rampage formula
    My Biggest Fear Is When I die, My Wife Sells All My Stuff For What I Told Her I Paid For It.
    79 SB threads and 32 IB Threads across 4 rigs 111 threads Crunching!!
    I am Xtreme
    Dec 2001
    S.W, Florida
    Quote Originally Posted by OldChap View Post
    Do not get far enough to install drivers. With the 9800 installed I never get far enough to complete OS install.
    Xtreme Legend
    Mar 2008
    Plymouth (UK)
    I would set up using the 7600gt grt all mb drivers and os sorted then swap to the gx2....I've had to do that in the past on a k9a2 platinum (I used a 7800gt) which is now folding for some months with gx2's and a 98gtx
    I am Xtreme
    Dec 2001
    S.W, Florida
    I did that, installed newest drivers then switched cards. It will not go into windows.
    Xtreme Legend
    Mar 2008
    Plymouth (UK)
    Lowest possible screen res before changeover?...try both dvi outputs...clutching at straws a bit...all power lights on?....primary card blue light on?
