Results 1 to 5 of 5
Thread: A good 500watt PSU Modular.
    revlimiter9000
    Guest
    I need a new psu for my core i7 build. What psu would be recommended so that I can use with a UPS unit (if I chose to do so). I would like for it to be modular so that I do not have cables all over the place.
    L-l-look at you, hacker.
    Jun 2007
    Perth, Western Australia
    HX-620 is probably the gold-standard mid-wattage modular unit. I'm not sure what you mean by able to be used with a UPS - any PSU that takes a standard kettle-plug connection and ends in a standard fitting will be usable with a UPS, you don't need to look for special compatibility or anything.
    Rig specs
    CPU: i7 5960X Mobo: Asus X99 Deluxe RAM: 4x4GB G.Skill DDR4-2400 CAS-15 VGA: 2x eVGA GTX680 Superclock PSU: Corsair AX1200
    Foundational Falsehoods of Creationism
    Oct 2006
    England, UK
    Corsair HX520W
    revlimiter9000
    Guest
    I thought that you needed a special psu so that you can use it with a UPS unit. I have decided to go with the HX620. Thank you again for the assistance. I learned something new today.
    May 2009
    im glad someone helped you out buddy.
Members who have read this thread: 0
There are no members to list at the moment.
