Inspired by Mick's awesome design...
add a splash of VoodooPC's latest Omen case...
add a dash of TJ07's uber simple case ideas...
and Monkeyin' around a bit here and there...
voila!
- top 2 bay area... prolly a screen.. maybe move the power button and connectors there?
- 2x 5.25 bays, upper bay with 2xslot drive slim ODD's (i dont see myself needing so many 5.25" bays...)
- HDD cage is cooled by downblowing 140mm fan over 6x2.5" HDD spaced at least 10mm apart for cooling...
- Pump Station... fits dual DDC3.2x sized pumps...
- HDD cage and Pump station is hidden via removable cover panel.
- Res mounted on the visible side panel of the HDD cage
- Upper Radiator Placement: it can fit up t a 140.2 sized radiator, pending size of PSU
- Lower Radiator Placement: yeppers, you can fit a 140.4 sized rad+Push/Pull Fans sitting on it's side down there...
- ample space behind MB tray to hide cables
- ample space hidden by conduit between Bay Risers and MB Tray to hide all cables
- removable MB tray
- removable Access Panel at back to access Rad fittings and whatnot... maybe drainport?
well, this is not 100% complete... still working progress.
and yea, i'm kinda fond of VoodooPC... and the front was a bit boring so i just put it there for now...
it just started by doodling when i had spare time... and as said, inspired by Mick, Charles_h's works... and all the other awesome worklogs over at XS...
i tried to keep my design quite simple and clean...
- the front/back panels are identical, except the cutouts.
- the midplates are identical, except for the cutouts.
- the top and bottom panels are identical, except the cutouts.
- 4x L Brackets to hold all the panels together...
that way, it is matter of making 6 pieces, then you have the exterior of the case
anywhoo... it's just some doodles... so go tear it appart with your Crits and Comments....
yea, yea, yea, yea... it's very voodoo omen inspired... ha ha ha... ok, i said it...
and as for tubing... i just LOVE the way structred tubing looks when you pass by any refinery... so i wanted to use some form of stiff tubing to give those shapes.
hence i was bugging Waterlogged a bit about all them questions on structure tubings...
and one more thing... i don't know why Yellow... maybe it was all thems dancin bananas...
