Hi there, just a quick Q. What would be the best way to get accurate CPU temp readings? I was looking at an infrared thermometer but that would only measure the side of the IHS?
i7 920 | Asus Rampage II gene | 6GB ocz Blade | 4870x2
I thought the internal temp probe was fairly accurate on an I7?
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
My BIOS temps are not accurate as it is impossible to get below ambient at idle. Realtemp is what I use because it gives higher temps then anything else and I figure at least I know I have head room.
