Neoprene
does any1 know any retail stores that sell Neoprene and what is a good thickness for inslalting a GPU,CPU,NB for a water chiller
Not in the US.
Personally I use an old mouse mat, thats about 8mm thick.
wouldn't that be alittle to thin
You can double it up, I stuck mine with hot glue and some super sticky double sifed foam tape I had.
If I was doing one now id think about making a wire heater to reduce condensation.
Look for a thing called "Rubaflex" or "Armaflex" - thats perfect, i can make a pic of it, its really neoprene foam in large quantaties, mine's 19mm thick and ill use it in the cascade
were would go to find that i checked homedepot.com and couldn't find it there
Ekhm, if i say berling.com.pl you probably wont buy it there as its a polish shop and probably you wouldnt understand a word ;]
i think i will just get some from dangerden.com what are some good thinknesses that i should buy
I changed my mind now i'm just going to use my inslution in a can and make some pads
- You may not post replies
- You may not edit your posts
Forum Rules
