I have a new GTZ on the way, and I'm trying to find out in advance if the 775 backplate that it uses is functionally identical to this one (in terms of threading esp).
If not, I guess I should get a head start removing my motherboard.
Please elaborate.
What are you trying to find out...
im pretty sure it is, from what i remember it looks exactly the same as the one i put on mine...
SYSTEM
i5-375K - ASRock Z77 Extreme4 - 8GB Samsung DDR3 - HIS 5850
Water Cooling
EK FC5850 - EK Supremecy - DDC-3.2 w/XSPC Top -Swiftech MCR320-QP - EK Multioption 150
“You Americans are so gullible. No, you won’t accept communism outright, but we’ll keep feeding you small doses of socialism until you’ll finally wake up and find you already have communism. We won’t have to fight you. We’ll so weaken your economy until you’ll fall like overripe fruit into our hands." Nikita Khrushchev
Thanks for the replies. Guess we'll find out tomorrow for sure.
- Have a backplate installed on my mobo already (the one I linked).
- Looks very similar to the GTZ backplate, so if they turn out to be interchangeable, I don't have to go through the aggravation of tearing out my board just to replace the backplate behind the board.
That picture is 100% the same, except my GTZ sticky pad was a full square
So, the final verdict: the backplates are not interchangeable.
The threading is exactly the same and the GTZ thumbscrews fit fine. But the "legs" on other backplate protrude 1-2mm more through the mounting holes, so the thumbscrews bottom out faster. The end result is that the pressure is less than with the GTZ backplate. And in my case, the problem is exacerbated by the fact that I have a lapped CPU and the GTZ is pressure-optimized for non-lapped CPUs.
It worked out to be about 5-6C worth of difference.
So yes, I ended up having to take out my motherboard in the end which I was hoping to avoid. Well it was worth a shot anyways.
why not just file down the legs on it
3770k, M5E, kingston 2x4GB cfr
samsung 2TB F4EG, samsung 840 250GB , CM690II, corsair 750tx
