Hey guys,
I am planing of getting a triple 4890 setup for benching.
I want to liquid cool it.
Now, my main issues are:
1. What blocks to get ? looks like the EK are nice, though a bit expensive for 3 cards at 110 a block.
The XSPC are very cheap at PPCS but sold out
Can anyone confirm compatibility of blocks ? I want to get the stock Sapphire design, shouldn't be a problem right ?
2. I am going to set this up on a Foxconn Bloodrage GTI board, and its PCI-E layout is a mess for CFX.
You got the upper 2 PCI-E X16 together, then a PCI and another two PCI-E X16, so 2 cards will have to be used in 0 slot configuration.
I need a proper adapter but couldn't find one yet, they all fit to 1/2/3 slot spacing but I need 0 slot config.
3. Do you think and MCR 320+D5 will cut if for 3 cards overclocked (probably with higher voltage than stock) ?
I have one MCR320 cooling down 4870X2 easily with just 2 fans working, so 3 4890 shouldn't be too hard I figured.
Help is much appreciate, thanks
