I have read the thread you posted dctokyo already. I have all power saving features disabled in bios. Thanx for your help anyway
Intel i7 3770K (4.8Ghz@1.36v) ~ Asus Maximus V Gene ~ 8Gb G.Skill Ripjaws X 2133 C9 (@2400 C10) ~ Asus GTX 670 DCUII (1230/7000) ~ Samsung 840 Pro 128Gb ~ WD Black 1Tb ~ Corsair AX 850W ~ X-Fi Titanium Fatal1ty ~ Epoz Aktimate Mini ~ Ducky Shine Blue Led /w MX Red ~ Logitech G700 ~ Samsung S27A850D 27" (2440x1600) ~ SilverStone TJ07B-W
WaterCooled by XSPC Raystorm ~ TC PA 120.3 + 3xAP 15 ~ MCP655 with EK-D5 X-Top Rev.2 ~ EK Multi 250
Powered by APC Smart-UPS SC 1500 ~ MGE ellipse premium 500
Is your system on the same circuit in your home with other things that you could unplug? Try unplugging other things in your home that are on that same circuit, turning off any flourescent lighting, etc etc and see if the buzz goes away.
Yes, Yellowbeard, a tall rough man with a big yellow beard
After moving into a new house I noticed a buzzing sound in the wall. Seemed to originate from the light switch. Turned out to be a loose screw that held the 120v wire (aluminum). Could a loose connection in the PSU cause this? Or maybe the supply cord isn't pushed in all the way?
