Hi guys,
Just finished building my new rig. I'm having a little bother with the cpu. Its being cooled by a D-Tek FuZion V2 on its own loop with a 360mm rad. The cpu idles at:
As you can see there is almost a 12c difference between cores 0,1 and cores 2,3. Its the same on full load:
The block is sitting properly, would more thermal paste help ??
Also, the mobo is an Asus Rampage Formula. The software that came with the mobo seems to overclock the CPU slightly as you can see in the full load picture, would it be the software that could be causing it ??![]()
Saaya yupp, I agree
What is the voltage? 1.8V?
