+ Reply to Thread
Results 1 to 5 of 5
Thread: COOLER MASTER Gladiator 600
    Xtreme Enthusiast msgclb's Avatar
    Oct 2006
    35n28, 97w31
    1
    I need a case but it has both a height and depth restriction. The COOLER MASTER Gladiator 600 meets both requirements. I just recently noticed that CM has two versions of this case.
    RC-600-KWN1-GP (with side window)
    RC-600-KKN1-GP (without side window)
    The only images that I've seen are from the version without the side window. Has anyone seen an image of this case with the side window? If so, could you post a link or image?
    | Intel Core i7-2600K | ASRock P67 EXTREME4 GEN3 | G.SKILL Sniper Series 8GB (2 x 4GB) DDR3 1866 | EVGA GTS 450 |
    | Swiftech APOGEE Drive II CPU Waterblock with Integrated Pump | XSPC RX360 | Swiftech MCP655-B Pump | XSPC Dual 5.25in. Bay Reservoir |
    | Thermaltake 850W PSU | NZXT SWITCH 810 | Windows 7 64-bit |
    Xtreme Addict Mech0z's Avatar
    Feb 2008
    Denmark / Aarhus
    1
    Desktop I5-3570k, 8GB Ram, GTX 560, Silverstone TJ08-E, Crucial M4 128GB, 750W Silver Power, ASUS P8Z77-M
    Laptop ThinkPad W520 2720QM /2 x 4 GB ram / Quadro 1000M / Crucial M4 128GB + 500Gb Hdd / FHD Screen / Intel WiFi Link 6300 AGN WLAN / 9 Cell Battery
    Laptop 2 New Macbook Pro Retina / i7 QuadCore / 650 GT / 16GB Ram / 512 GB SSD
    Server: Athlon II X4 640, ASROCK K10N78, 8GB Ram, LSI MegaRaid 8 port, 64GB Vertex 1, 5 x 1 TB WD Raid6, 3 x 3TB Seagate Raid5
    Oct 2006
    35n28, 97w31
    1
    Banned
    Jan 2009
    0
    looks almost like one of there old cases refined
    Xtreme Guru
    Aug 2005
    Burbank, CA
    0
    Hope its cheap, i can use it for my customers cheap builds.
+ Reply to Thread
