sourceOriginally Posted by www.theregister.co.uk
yes it is gone be really really expensive and the size will probably not be really big, but still 500MB/sec from a single drive
i hate to call repost
i7 2700k 4.60ghz -- Z68XP-UD4 F6F -- Ripjaws 2x4gb 1600mhz -- 560 Ti 448 stock!? -- Liquid Cooling Apogee XT -- Claro+ ATH-M50s -- U2711 2560x1440
Majestouch 87 Blue -- Choc Mini Brown -- Poker Red -- MX11900 -- G9
Forget moving parts!
Cool! An actual sensible use for piezoelectricity! I wonder what the capacity and price will be like.
Asus Rampage II Gene | Core i7 920 | 6*2GB Mushkin 998729 | BFG GTX280 OCX | Auzentech X-Fi Forte | Corsair VX550
—Life is too short to be bound by the moral, ethical and legal constraints imposed on us by modern day society.
Those specs defeat current SSDs today. In a year or two, I think SSDs may catch up to this performance and at a far better value than we buy them for today. Still, that's a hell of a lot performance for a first generation product. I welcome the idea of having more than one high speed permanent storage format to choose from in the future.
NEATO!
The fusion IODrive is still probably a better deal, all things considered.
Agreed, that is impressive for a 1st gen product. SATA6 be prepared to be maxed out upon implementation!
This will never work in the long run. 64 heads is way too many for this to be reliable. You see lots normal drives with failed heads and those have like 2-8 of them most of the time.
the spec number are quite high, but it is still a mechanical device. What are the access times on this thing?
Rig 1:
ASUS P8Z77-V
Intel i5 3570K @ 4.75GHz
16GB of Team Xtreme DDR-2666 RAM (11-13-13-35-2T)
Nvidia GTX 670 4GB SLI
Rig 2:
Asus Sabertooth 990FX
AMD FX-8350 @ 5.6GHz
16GB of Mushkin DDR-1866 RAM (8-9-8-26-1T)
AMD 6950 with 6970 bios flash
Yamakasi Catleap 2B overclocked to 120Hz refresh rate
Audio-GD FUN DAC unit w/ AD797BRZ opamps
Sennheiser PC350 headset w/ hero mod
Increasing the number of heads = increasing number of moving parts = less reliability, more noise.
It's like moving backwards.. just let the tech die.
Yes, like a 100 year old steam train with 20 engines.
GUYS! Take 2 minutes and read the ENTIRE article. The problems you all speak of are addressed (likely to your amazement). This isn't your typical "mechanical" hard drive. Every bit on the recording medium oscillates under the 64 read heads so there is no seek time, very little latency, and very little movement.
Being as there are no revolutionary parts or materials used, the price should ramp down pretty quickly when the world gets on board. Just like SSDs have in the last 18 months. I see this tech making more sense than SSDs for the next few years while flash technology continues to mature.
Agreed. The read heads are actually NOT moving, that data underneath them is moving. So, per head there is much smaller amout of data to read = higher speed (:
ASUS P5E Deluxe X48 | C2Q Q9550@testing[Fuzion v2+MCR320+MCP655] | G.Skill 4x2GB F2-8800CL5D-4GBPQ@testing | Sapphire 4870X2@ testing | 150GB WD VelociRaptor + 2xWD6400AAKS | Chieftec CFT-850-14C | Iiyama E2403WS | Razer DeathAdder | CM CosmosS Black
access time may suck, but 64 parallel reading heads probably makes up for it. this is like the GPU vs CPU of hard drives
Fail. Is that thing using IDE?
Core i7 920 D0 B-batch (4.1) (Kinda Stable?) | DFI X58 T3eH8 (Fed up with its' issues, may get a new board soon) | Patriot 1600 (9-9-9-24) (for now) | XFX HD 4890 (971/1065) (for now) |
80GB X25-m G2 | WD 640GB | PCP&C 750 | Dell 2408 LCD | NEC 1970GX LCD | Win7 Pro | CoolerMaster ATCS 840 {Modded to reverse-ATX, WC'ing internal}
CPU Loop: MCP655 > HK 3.0 LT > ST 320 (3x Scythe G's) > ST Res >Pump
GPU Loop: MCP655 > MCW-60 > PA160 (1x YL D12SH) > ST Res > BIP 220 (2x YL D12SH) >Pump
I don't think it's fail. Especially not when SSD's cost so much for crappy 128GB and have all sorts of stupid problems with controllers. Every alternative is good.
If read/write is 500MB/s and the price is right, i wouldn't even mind access times that are the same as with standard HDD's.
Intel Core i7 920 4 GHz | 18 GB DDR3 1600 MHz | ASUS Rampage II Gene | GIGABYTE HD7950 3GB WindForce 3X | WD Caviar Black 2TB | Creative Sound Blaster Z | Altec Lansing MX5021 | Corsair HX750 | Lian Li PC-V354
Super silent cooling powered by (((Noiseblocker)))
It's about time... they reinvent the HDD, after 152 years of models based on that old technology (only faster and automatized):
Beyond IT products, they should change the automobiles as well. ^^ Cause in their case it's a necessity. The oil age will be over in less then 20 years and current cars will work only like this:
..and if the heads matrix is gone faulty, you just peel it off and replace with a new one!
