Top pci-e slot is having issues. Whenever I use any GPU the system locks up after a while. If I use the bottom pci-e slot its fine. Any ideas?
i7 920 | Asus Rampage II gene | 6GB ocz Blade | 4870x2
Try a different card if you have one and see if you can produce the same problem. If you can, maybe it's time to do an RMA because that slot might be bad.
Asus Rampage II Gene, Xeon W3550 D0 Mushkin PC3-2000 6GB, BFG 9600GT OC 512MB DDR3
Asus A8N32-SLI Deluxe 1.01G, AMD A64 4000+, 2x1GB Ultra PC-3200, EVGA 7600GT 256MB DDR3
Asus MA378-T with AMD Athlon 64 X2 7850
ECS 945GCT-M/1333 v3.0, Intel Celeron E1400, MSI 8500GT 256MB DDR3
BIOStar P4M900-M7 Rev. 7.0, Intel Celeron 440, 1GB Kingston, 6600LE
Gigabyte M61PME-S2P with AMD Athlon 64 LE-1660, EVGA 8500GT 1GB DDR2
My Gene II heats up enormously making it very unstable. The PCB of my GTX 285 and the closest dimm near the NB heatsink get very hot too. Installed an Antec spotcool and NB temps dropped a freaking 30°C from 92°C to 62°C. I wouldn't use the X58 in an HTCP case with a big OC... those things must be ovens inside...
Question : Why do some overclockers switch into d*ckmode when money is involved
Remark : They call me Pro Asus Saaya yupp, I agree
May be worth flashing the lastest BIOS and increasing your PCI-E clock as it might help.
thanks for the replies. Turns out one of my OCZ blade sticks was bad.
