hi do any of you guys have 120mm fans mounted on the side panel? I know they give you mounts, but there arent enough holes for four 120mm fans
how can I mount my 120 mm fans? tried double sided tape and dint work. thanks
Watch 24!
Q6600 G0 w/ Scythe Zipang
A Data 2x2gb DDR2-800
Corsair 750w PSU
8800GTX
320gb Maxtor HDD
Audigy 2 ZS
RocketFish case
the double-sided tape will not hold them, I tried in my CM AMMO, he fell with time and vibration, the idea is you make holes in the side and the Haf 932! i would rather you put the four fans!
good luck!
SORRY FOR MY BAD ENGLISH!
