Currently I use a 355 with a res top because I wanted a pump that could overcome the pressure created by a supreme along with 2 QDs a 4x120mm rad all in one loop. The setup gets about >1.15GPM according to koolance flow sensor.
I am now looking into a new loop with the following:
Supreme LT
EK 260 gpu block
3 QDs
2 duel 120mm rads (Black ice one thin one thick)
1 tank
1 koolance flow sensor (INS-FM17)
I am wondering if I am better off using the 655 for this as I do not think this will be as restrictive as my current loop therefore the 665 should get better flow rates.
*Assume 1/2ID
Yes it need the flow sensor because I am making this for my little sister and she needs the system to basically run its self. She has never had a high end computer and because I got a 920 and a cheep gigabyte motherboard lying around I figure for $1000 I can make her a pretty sweet system that also looks great
I am pretty sure the 355 is the right choice but I want to check if you all think it is up to the task.
