Canon 5D Mark II (Canon 50mm f/1.2L | Canon 135mm f/2L | Canon 24-70mm f/2.8L | Contax Zeiss 85mm f/1.4 | Zuiko 21mm f/3.5 | Crumpler 7MDH | Hitech filters + Lee Foundation Kit | B+W filters)
Hasselblad 201F (Zeiss 80mm f/2.8 CF | 2x A12 Back | Domke F-4AF)
Nikon F3HP (Nikkor 50mm f/1.2 | Nikkor 55mm f/1.2)
Images: Flickr
same here. got it yesterday. i will post some pics when i have a chance. i can't wait to install it.
did you install the cooler yet Marin? what are the results?
i got my AC GTX 280 installed last night. took two damn hours.
good luck..
PC-A04 | Z68MA-ED55 | 2500k | 2200+ XPG | 7970 | 180g 520 | 2x1t Black | X3 1000w
You're gonna have bucket loads of fun installing that thing Marin. Good luck getting the 4870X2's clamps back on.
dng, everyone I know who has got one (including myself ) has been blown away by how cool it keeps the card and how quiet it is. It's magnificent after you get past installation
Yes it is a pain putting those X-cross supports on to hold the heatsink onto the PCB. It took me an hour to do it and I ended up breaking a screw, Thank god there was the same screw in the stock hatsink around the fan, if not I would have been screwed. But so far so good it is keeping my card nice and chilly
Installing it tomorrow.
Images: Flickr
Awesome...im thinking on getting this cooler...the stock cooler on the 4870x2 is unbearable at high speeds...hair dryer kind of thing.
C'mon guys..where are those pictures? What about temps?. ...does it comes with some kind of cooler for the mosfets?
Vic.
Gigabyte EX58-UD5 // Intel Core i7 920
SuperTalent PC3-12800 3x2gb
ATI 4870X2 2gb
Samsung 1TBx6
Coolermaster Silent Pro Gold 1000w
Coolermaster Cosmos
Dell u3014
Mine came in last week - crossed paths with the 4870X2 that's being RMA'd, so it will be a while before I can install. Couldn't believe what a monster this thing is! Glad to hear it is quiet and doing a good job of keeping things cool.
Images: Flickr
if its so easy to install how about a pic instead of some sport shots. edit i couldent see the card at all lol
5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
Um there is a pic of it installed...
EDIT: Then it's all good now. Yeah, the cooler is that massive that it's hard to see the card. But one things for sure, it is insanely quiet and cools extremely well. At 100% fan speed it's quieter than the stock cooler at 30%.
If you still have a 4870x2 with a stock cooler and have no plans of going water, this cooler is a must.
Images: Flickr
very artistic photo Marin. i might use it as a desktop background if you don't mind . so it was easy for you to install huh. for every, everything was fine until i had to install the X brackets back on. that was an experience. i never sweat so much before installing a piece of hardware . i actually had to go back and adjust one of the brackets. anyhow, my results are, idle cpu1 41, cpu2 43 and fan is at 50%. i didn't have time to take the load temperature, but i will report back. all in all, it's a great cooler. the best alternative to going water cooling. i definitely recommend this cooler if you have a 4870x2. btw, i had to use the 3 screws from the stock fan. the screws for the X brackets are too short.
i'm waiting for the bikini babe shot...
i7 3610QM 1.2-3.2GHz
I thought getting the x brackets on was really easy. Just as easy as it was the first time when I reapplied TIM for the stock cooler.
Images: Flickr
So tempted to get two of these for my xfire setup.
i7 940/Rampage 2 Extreme/Corsair 6g Dominator/Corsair HX100W/GTX 580/SSD
thats serious cooling, hope u hit some high clocks, you can cool a lawnmower with that
Case-Coolermaster Cosmos S
MoBo- ASUS Crosshair IV
Graphics Card-XFX R9 280X [out for RMA] using HD5870
Hard Drive-Kingston 240Gig V300 master Seagate 160Gb slave Seagate 250Gb slave Seagate 500Gb slave Western Digital 500Gb
CPU-AMD FX-8320 5Ghz
RAM 8Gig Corshair c8
Logitech 5.1 Z5500 BOOST22
300Gb of MUSICA!!
Steam ID: alphamonkeywoman
http://www.techpowerup.com/gpuz/933ab/
What mosfet temps are you guys getting under full load?
How loud is that beast?
Absolutely quiet. Like mentioned above
100% on the accelero fan speed is as quiet if not quieter then 30-35% on old heatsink!!! My load temps are low in the 50s (this is overclocked!). About furmark: even with stock heatsink the vdcc temps reaches 100c. Pay no attention to this though as it will have no effect on gaming since nothing uses the card like furmark. Also a question:
Did you guys use the 8 pin to 6 adapter (I don't know why they did this) or stick in the 8 pin? If you use the 8 to 6 then what are your maximum overclock clocks?
MSI P67 GD65 B3
2500k 4.8
GTX480 835/1650/2000
8gb ram
Win7
So how many slots does the card take in total with the accelero on it?
