Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: Up in smoke.... Thats where my capacitors go....
    Apr 2008
    So another motherboard bites the dust....
    So I wake up and turn my pc on and I hear a small pop, but since nothing is wrong with the computer (it was still working), I think nothing of it and continue to browse the web for about 10min, then I go and take a shower.
    Upon coming back from the shower there is a strong acidic smell in my room. A smell of burnt electronics.
    My computer is no longer on playing music like I left it. Its off. I feel terror.
    So I unplug everything and pull the board out, removing all parts. I find the following:
    This has happened once before with this board model, although last time it was not near as sever. Guess I'm overclocking too hard as there is no other explanation as to why it keeps happening. It was even the same caps as last time.
    Rma time.
    Q9650 @ 4ghz | EP45-UD3P | 5870 |
    Aug 2005
    Yikes... how much were you pushing it? I have the Deluxe version of the board (P5Q Deluxe), and now I'm a little paranoid. We even have similar specs.
    Sucks that it had to die on you
    .:: Gaming PC Specs ::.
    Case: Antec Nine Hundred
    CPU: Intel Core i7-2600K @ 4.6 GHz, 1.44v (cooled by Xigmatek GAIA) [IntelBurnTest{Linpack} stable]
    GPU/Monitor: VisionTek HD 6950 @ 6970, 950 MHz/1375 MHz 1.30v + Sony BRAVIA 32EX400 1080p
    Motherboard: GIGABYTE Z68XP-UD4 F5
    Memory: 16 GB (4x 4 GB) Corsair Vengeance LP DDR3 1600
    Hard Drive: 2x Seagate 500 GB 7200.11 RAID 0 & RAID 1 (Matrix RAID) + 1x WD Caviar Black 640 GB
    Sound: Creative SB X-Fi Fatal1ty Profess1onal, Logitech X-530
    PSU: Corsair AX-1200 (1500W PSU!)
    O/S: Microsoft® Windows 7 Ultimate SP1 X64
    Banned
    Apr 2008
    Brisbane, Australia
    Sorry for your loss.
    Looks like your mosfets said hell no.
    Xtreme Cruncher
    Jun 2008
    pacific NW usa
    wow.that just sucks.to happen once is bad but twice.what are your voltages?and hows your cooling?
    is this kind of thing caused by heat from too much voltages?im kind of scared for my board too.
    please let us know all details that you can.again sorry buddy
    _________________________________________________
    ............................ImAcOmPuTeRsPoNgE............................
    [SIGPIC][/SIGPIC]
    MY HEATWARE 76-0-0
    May 2006
    Not the caps, looks more like bigtime mosfet meltdown. Which specific Asus mobo (the one in your sig?) and how much were you pumping into it?
    'He is no fool who gives what he cannot keep to gain what he cannot lose' - Jim Elliot
    Click on the pic to download a free pdf sample of the bestselling book!
    Sep 2008
    +1 your mesets said no more... i would have to ask.... what were you pushing vcore wise.... either way that is NOT GOOD...
    If tahts happened on 2 boards.. check your thermal pads make sure when mounted the mosfets are not pusing through the pad and making contact
    This is my signature, there are many like it but this one is mine..
    Jun 2008
    +1 for what vcore were you using? PSU?
    Aug 2007
    Haverford, PA
    This is the reason (or one of them) that I take off my MOSFET coolers and re-grease them with Arctic Ceramique or MX-2 before the board goes into use. I am mega paranoid about them going up in smoke :P
    ~FoxDie~
    CM HAF 932
    MSI Z68A-GD65
    2600k Watercooled @ 4.6 GHz
    Powercolor HD6950
    4x4GB G.skill Ripjaws X 2133
    2x Crucial M4 128GB R0
    WD 1TB Black
    Feb 2007
    That's why I don't like asus. They screwed me over more than 3 times.
    Banned
    Apr 2008
    Brisbane, Australia
    Anus may be very anus like but I didn't get total contact on my DFI mobo either. Everyone has this issue.
    I am Xtreme
    Sep 2006
    Isues maybe due to ya phase change mount ?
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
    May 2004
    Quote Originally Posted by pur View Post
    Rma time.
    Will Asus still honor the board? What if they say it's user's fault (High OCing resulting in too much heat)?
    Asus Rampage II Gene, Xeon W3550 D0 Mushkin PC3-2000 6GB, BFG 9600GT OC 512MB DDR3
    Asus A8N32-SLI Deluxe 1.01G, AMD A64 4000+, 2x1GB Ultra PC-3200, EVGA 7600GT 256MB DDR3
    Asus MA378-T with AMD Athlon 64 X2 7850
    ECS 945GCT-M/1333 v3.0, Intel Celeron E1400, MSI 8500GT 256MB DDR3
    BIOStar P4M900-M7 Rev. 7.0, Intel Celeron 440, 1GB Kingston, 6600LE
    Gigabyte M61PME-S2P with AMD Athlon 64 LE-1660, EVGA 8500GT 1GB DDR2
    Jun 2008
    Wow thats amazing
    If you were running your Q6600 @ 4.3GHz (like in your sig) then i'm not really surprised it happened, the P5Q isn't a high end mobo.
    Mar 2009
    Irvine,CA
    U are really lucky, cus that looks like u had a small fire there.
    Jun 2008
    Quote Originally Posted by dpokrajac0 View Post
    Lucky it didn't spread...
    Sep 2008
    actually very small chance of major fire.... ive had this happen when testing motherboards before its actually quite quick, a flash pop flame then just kinda boils the upper layer of the board.... i would say your mosfet when mounting taht cooler may have torn a little or pushed through the pad, and caused it to ground or short....
    not ot mention if teh fet cooler was touching a cap, it would have a ground point then it was just a matter of time...
    A word of advice.... check clearance on all surrounding products when mounting coolers.... also take teh pad (so not use just ceramique) unless you like replacing boards.... but put ceramique directly on teh fets then place the pad directly on teh cooler the mount it on the fets.... try to mount it while lining the holes up directly is possible... and wiggling you do could cause the thermal pad to tear and give you a future shorting point
    Xtreme Mentor
    Aug 2008
    Australia
    Wow, that is some serious damage there. I'm also interested to know what vcore, Vtt and vPLL you were running, and what PSU you are using.
    Ci7 990X::Rampage III Extreme::12GB Corsair Dominator 1866C7GT::2 x EVGA SC Titans in SLI::Corsair AX1200::TJ07::Watercooled
    Ci7 920 3849B018::Rampage II Extreme::6GB GSKILL Trident 2000C9 BBSE::EVGA GTX580::Antec Signature SG850::TJ09::Aircooled w/TRUE 120X
  18. #18
    May 2009
    I am sorry for your loss but how come you didn't think much of "the pop". Any overclocker knows what that means....
  19. #19
    May 2005
    Quote Originally Posted by jcniest5 View Post
    I doubt it, they'll know something is up with the greased socket.
    Work Rig: Asus x58 P6T Deluxe, i7 950 24x166 1.275v, BIX2/GTZ/D5
    3x2048 GSkill pi Black DDR3 1600, Quadro 600
    PCPower & Cooling Silencer 750, CM Stacker 810
    Game Rig: Asus x58 P6T, i7 970 24x160 1.2v HT on, TRUE120
    3x4096 GSkill DDR3 1600, PNY 660ti
    PCPower & Cooling Silencer 750, CM Stacker 830
    AMD Rig: Biostar TA790GX A2+, x4 940 16x200, stock hsf
    2x2gb Patriot DDR2 800, PowerColor 4850
    Corsair VX450
  20. #20
    Apr 2007
    smells like an Asus
    i3 2100, MSI H61M-E33. 8GB G.Skill Ripjaws.
    MSI GTX 460 Twin Frozr II. 1TB Caviar Blue.
    Corsair HX 620, CM 690, Win 7 Ultimate 64bit.
  21. #21
    Sep 2008
    wow... i didnt know people still greased their sockets.... a hair dryer and a lil time might fix taht though
  22. #22
    Xtreme Mentor
    Feb 2007
    Oxford, England
    lols my board (abit) has poped caps still runs though somehow lols =)
    "Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
    //James
  23. #23
    Xtreme Mentor
    May 2008
    Dude, that is nuts. Judgeing by the pad on the mosfet sink a few of the vrms weren't even making contact with the pad. I'm using the same mosfet sinks on my deluxe and was able to use the stock backplate and screws.
  24. #24
    Banned
    Mar 2009
    Brooklyn, NYC
    hes not going to tell you the voltages until he tries an RMA w/ asus. if he were to post his real results here he would get pwned by asus when they see that he was lying.
  25. #25
    Apr 2008
    Well thats a lot of posts.
    Yeah I was running 1.5v in the bios, I honestly don't remember the other settings. The board has been running 24/7 for almost a year, only a quick power cycle every few weeks. So the other settings have been long forgotten. The heatsinks on the mofsets never got more then warm when under a load.
    As far as posting the "results" they are already on the forum, i believe in my phase thread so . All I was doing was using a board feature anyways. As far as greasing the socket, I'll never do that again. It was a mistake this time and there are better ways. Its pretty easy to clean off if you know how as well. I'm not looking to cheat anyone, but I feel I used the board as it was intended.
    I had theorized that the cap leaked electrolyte and then it caused a short on the mofsets, resulting in some warm results. Once I took the board off the the tray I noticed that it burned off some of the powder coat on the aluminum. Yikes. It is possible that the mofsets just quit, but they were never more then warm. On the old mobo, the mofsets didnt go, a cap leaked electrolyte, but it was just below the mofsets, so no short that time, but who knows. On the bright side, everything else still works.
    No, I'm not sure it will get rma'd again. If it doesn't its no big deal. I will buy another but probably not asus. The rma last time was painful. It took forever, then they sent me the wrong motherboard (an AM2 board), and then when i finally got someone on the phone I was told to take pictures to prove they sent me the wrong one and email them. Only the rep i sent the pictures to got off work, so I had to go through the entire phone tree again, and send the pictures again. After 7 weeks, I got the correct replacement board. Unacceptable.
    With all of that, anyone have suggestions for a non-asus board?
    Just needs to be DDR2 and have a P45 chipset. Crossfire not needed.
    Not interested in i7 at the moment. Performance is plenty high for me at 4.3ghz. A small jump with i7 is not worth the 500-700 it would cost to upgrade.
