Hello. I know there have been a lot of discussion over clear tubing and clouding. So I thought I'd make a little "test" to see what happens to the tubing after a while. I know some have come to think that the PT-nuke makes tubing cloud. We will just have to wait and see.
So basically what i did was to take 3 small pieces of tubing and put them in 3 sterilized jars. Three different jars. One with PT-PHN and one with only distilled and finally a jar with a silver chain and distilled water. The distilled is not a good option because of Algae and stuff. But I just wanted to add it to see what it does to the tubing as some kind of baseline.
And when I say distilled water I mean deionized water (so there is no confusion).
3 Small pieces of tygon B44-4X tubing.
The tubing was put in a sterilized container and shaken with distilled water to ensure that they where clean (tubing is also new from sidewinders and came in a plastic bag)
This is how the jars look like. Its just standard glass jars that I have cleaned and sterilized with boiling water.
I just had boiling water in the jars. (It was really hard to pour out the water with them being about 90 degrees celcius). Not the best but good enough. There may be some junk left in some corner or something. But It should be clean do to the high heat.
I also cleaned the silver chain and poured boiling water over it an let it be there for 1-2 minutes.
Done, everything got sealed with the lids.
The jar with the "ABBA" lid have distilled water + PT_Nuke -PHN (half a drop, maybe to strong).
The jar with the "ICA" lid is just distilled water.
The jar with the "Felix" lid have a silver chain and distilled water.
And finally I put the jars on a radiator (no not a "radiator" that you use in computers) so it have a high temperature. I would guess it keeps a temperature of 30-40 degrees.
Thoughts
I know that the conditions are not a 100% accurate but it should be similar. I try to shake around the jars when I walk by them. So the water will move in the tubing. I know this will not get super accurate but it should be quite good. And it should be consistent as all the jars will keep the same temp! (the values may fluctuate some degrees).
Note that I did this today. So if there is anything in my method you think I should change please say so now And also I will not have results until a few weeks at least!
If you where to guess how long will I take for each to cloud?! Myself I really don't have a clue but ill check it from day to day without opening the lids to ensure that no other stuff gets in the jar.
Martin and skinnee watch out!
