Results 1 to 9 of 9
Thread: Which RAM should I get for i7 920?
    Jan 2005
    Hey guys,
    I can't decide which RAM to get for my i7 upgrade. Here is a few of the kits I am looking at. The prices are in AUD.
    I'm looking at these kits:
    Corsair TR3X6G1600C8D 6GB http://www.pccasegear.com/index.php?...oducts_id=8670
    OCZ DDR3 PC3-12800 Intel i7 Edition http://www.pccasegear.com/index.php?...oducts_id=8657
    OCZ DDR3 PC3-12800 Platinum 3x2GB http://www.pccasegear.com/index.php?...oducts_id=8648
    OCZ DDR3 PC3-15000 Reaper 3x2GB http://www.pccasegear.com/index.php?...oducts_id=8698
    G Skill PC3-12800 PI http://newgskill.web-bi.net/bbs/view...d=g_ddr3&no=59
    I'm a novice overclocker so I don't really know much about timings and all that stuff. So I have a few questions about those kits I posted:
    1. Which kit would be the best out of those?
    2. Which kit would overclock the best?
    3. Which kit would be more suitable for my particular situation(Asus P6T, Either a D0 920 or W3520 and looking to get between 4000-4200Mhz)?
    4. Is there a different/better kit I should be looking at in that price range?
    Nov 2007
    Toronto, Canada
    Not sure of the price of the Pi in AUS, but out of that list, OCZ DDR3 PC3-12800 Intel i7 Edition seem to fit your needs and then some.
    GB 790XTA UD4
    GSkill Pi Black 2000 Cas9
    ASUS 4870
    Enermax Revolution 1050+
    http://www.heatware.com/eval.php?id=67661
    Jan 2005
    Quote Originally Posted by ReverendMaynard View Post
    The PI is about $199 AUD.
    What is the difference between the PI and PI Black that you have?
    Nov 2007
    Toronto, Canada
    Quote Originally Posted by Ice009 View Post
    400mhz
    GB 790XTA UD4
    ASUS 4870
    Jan 2005
    400mhz
    lol I read your sig wrong. That is a bit of a difference .
    Jan 2005
    OK guys I have narrowed it down to these two kits.
    OCZ Platinum OCZ3P1600LV6GK C7 kit Vs this Corsair TR3X6G1600C7 kit.
    Which one should I go with? Which would overclock better?
    Nov 2003
    Pretty much narrowed down to these kits also myself.
    The only test I was able to find where these two went head-to-head was a German magazine called PC Games & Hardware:
    http://www.etest-hardware.de/Testueb...-RAM.7133.html
    TR3X6G1600C7 came 3rd in that test, just below the Elpida Hyper based Blades and Dominator GT modules, and above the OCZ3P1600LV6GK in question.
    Where I'm at OCZ is cheaper, but your situation may vary. Don't know the difference between the chips inside, if any. I know they ain't Elpida Hyper, which is good
    Banned
    Jul 2009
    Lansing, MI and Tampa, FL
    Get Crucial value ram off newegg. They have D9JNL IC''s on them.
    May 2009
    Richmond, BC
    I suggest the second one
    SCHOOL PC
    CPU = i7 920 D0
    GPU = 2x GTX285 SLI
    Mobo = Asus P6T X58
    HDD = 3x 30GB Vertex SSD RAID0
    RAM =3 x 2GB Dominators1600
    CPU Block = Apogee GTZ
    GPU Block = 2x HEATKILLER® GPU-X˛ GTX285
    NB Block = Bits Power BLACK FREEZER///EK-Mosfet ASUS X58 KIT
    Case = MM U2UFO
    PSU = Corsair HX1000W
    GAMING PC
    CPU = I7 940
    GPU = 2x GTX 295
    Mobo = X58 Classified
    HDD = 3x 30GB Gskill SSD RAID0
    RAM =3x2GB Dominator GT
    CPU Block = Heatkiller 3.0
    GPU Block = Koolance VIDNX295
    NB Block = EK Acetal Full Coverage
    Case = SS TJ07
