Intel Reference P55 MB
CPU-Z
More Test and pic
CPU-Z
More Test and pic
i always thought lynnfield didnt have ht. but in cpuz that it has 8 threads, some error or what?!![]()
Weaker than 920 in Vantage CPU by around ~1000 pts.
www.teampclab.pl
MOA 2009 Poland #2, AMD Black Ops 2010, MOA 2011 Poland #1, MOA 2011 EMEA #12
Test bench: empty
Cinebench from the site.
i7 920 STOCK Cinebench: 15.2K
PII 925 STOCK Cinebench: 11.8k
Core i5 2.66Ghz STOCK Cinebench: 11.4k
Considering that the 2.66Ghz Lynnfield will be in the same price range as the PII 925, it looks like Intel has made it very clear what the purpose or the i5 will be: to keep PII in check.
Perkam
perkam, the cinebench had only 4 threads enabled.
whats the points of an i5 with all 8 threads?
I´m quite sure all the benches run is with single channel. A 2.66Ghz i5 will be almost identical to a i920. They use the exact same core. Only difference is dualchannel vs tripplechannel and ondie PCIe vs QPI+X58.
And a beefier turbomode on i5.
Cinebench is also abit proving of this. i7 gets way higher multiprocessor speedup. And they are identical.
Crunching for Comrades and the Common good of the People.
I wonder what the flash modules that fit in the little DIMM slot will cost. And what the speeds will be like for those.
I would be bold to say its useless for desktops. Its the robson flash cache for HDs. And depending on size I say 10-25$.
Unless you hook up some 4200rpm 2½" disk I doubt it will give much. And since we stand in front of the SSD revolution I say its dumb.
But again, its a reference/validation board that also applies to laptop designs. But even with intels 80GB SSD to cost something around 150$ at christmas time. Aint it time for robson to die?
well, intel CLAIMS robson boosts hdd speeds to that of SSD's...
their cinebench are a tad slow, but its not sc mem... for me sc is faster in cinebench than dc for some reason... not surprising, its the same on i7 iirc
must be really slow mem or the bios is really really untweaked, which wouldnt be surprising for a ref board...
lynnfield perf is nothing extraordinary at all...
how fast is a core i7 at 2.66 in superpi 1m with ddr3 1066 777 dual channel?
Core i7 with trip channel and dual channel has been shown to be within a few percentage points of each other in most applications.. so Core i5 will cannibalize Core i7 sales with it's lower price point and similar performance. Core i5 will be great for crunchers and such![]()
seeing the huge turbo boost speeds, i wouldnt be susprised if i5 even beats i7 in some tests since most apps are still single threadded...
of course, when overclocking this wont matter, but for stock performance turbo really makes i5 a whole lot more attractive
btw, did anybody else notice that westmere only supports ddr3 1066? 0_o
i think its cause it takes a lot of time to test and tweak the mrc code for 1333 and up... and they think its not needed...
but weird, i think 6 cores and 12 threads will def benefit from ddr3 1333 and up...
i7 uses the same DMI interface between ICH10R and X58.
i5/i3 uses DMI between PCH and the CPU. And PCH=ICH10R in functionality. X58 is simply a PCIe switch for 36 PCIe lanes. i5 got an ondie PCIe x16.
Also the performance wouldnt matter a single bit in those tests. The only outside thing that matters is memory.
Nope, its a good classic single instead of dualchannel
I compared it to an i7 with HT disabled. With HT on the multiprocessor speedup would be above 4x (I think it was 4.15x with HT on and 3.55x without HT).
The tripplechannel seems to outpace it and Intel selected memory timings for speed due to that. For Xeons only the higher end with fast QPI got 1333 to fuel the NUMA.
Core i7 920 D0 B-batch (4.1) (Kinda Stable?) | DFI X58 T3eH8 (Fed up with its' issues, may get a new board soon) | Patriot 1600 (9-9-9-24) (for now) | XFX HD 4890 (971/1065) (for now) |
80GB X25-m G2 | WD 640GB | PCP&C 750 | Dell 2408 LCD | NEC 1970GX LCD | Win7 Pro | CoolerMaster ATCS 840 {Modded to reverse-ATX, WC'ing internal}
CPU Loop: MCP655 > HK 3.0 LT > ST 320 (3x Scythe G's) > ST Res >Pump
GPU Loop: MCP655 > MCW-60 > PA160 (1x YL D12SH) > ST Res > BIP 220 (2x YL D12SH) >Pump
The original board back in october 2008 havent changed much
wow pciE is that small huh? makes it obvious again that x58 was NOT just a pciE hub![]()
wtf is wrong with intels board btw?
green pcb? 4 pin cpu pwm plug? no 90 degree angle sata slots?
not a single solid cap, 2+1+1 analog cpu pwm, cheap components, terrible slot layout, fugliest heatsink ever, not to mention the slot colors
motherboard looks like its forgot some stuff on it :P
"Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
//James
