+ Reply to Thread
Results 1 to 11 of 11
Thread: Major discrepancy between core and CPU temps
    Sep 2004
    0
    G'day crew,
    I have recently built a new system and I'm having some problems with the cpu. Specs:
    i7 920 C0 Stock settings and cooler currently
    DFI LP T3EH8
    6 x 2GB Patriot 1600MHZ C7 stock
    The Bios is set to shutdown at temps >100C.
    With ambient <22C, core temps at idle are 43,44,44,38 with CPU 34.
    Running Prime 95, core temps get into high 90s within a minute or so whilst CPU is still sub 50.
    I have reseated the cooler a couple of times using AS5 applied with 5mm bead method. I initially applied the cooler with stock TIM in place and had the same issues. I also have a TRUE on order, so if its just a cooler problem this should resolve.
    My main concern however is if the discrepancy between core and cpu case temps is abnormally high and if the CPU is defective, perhaps a problem with the internal heatspreader?
    May 2004
    0
    It could be a temp sensor defective.
    Asus Rampage II Gene, Xeon W3550 D0 Mushkin PC3-2000 6GB, BFG 9600GT OC 512MB DDR3
    Asus A8N32-SLI Deluxe 1.01G, AMD A64 4000+, 2x1GB Ultra PC-3200, EVGA 7600GT 256MB DDR3
    Asus MA378-T with AMD Athlon 64 X2 7850
    ECS 945GCT-M/1333 v3.0, Intel Celeron E1400, MSI 8500GT 256MB DDR3
    BIOStar P4M900-M7 Rev. 7.0, Intel Celeron 440, 1GB Kingston, 6600LE
    Gigabyte M61PME-S2P with AMD Athlon 64 LE-1660, EVGA 8500GT 1GB DDR2
    Mar 2008
    Pennsylvania
    1
    I wouldn't worry about idle temperatures, they tend to be very inaccurate. Put a load on it and see what happens.
    Your sensors really aren't that far off of each other compared to mine.
    Sep 2004
    0
    Quote Originally Posted by thebluemeanie1 View Post
    Sorry, didn't explain myself very clearly. The discrepancy occurs under load. ie. after the latest reseat, I am now able to run Prime 95 without Bios shutting down after 1 minute.
    After 5 mins. temps are:
    96,98,99,93 and the CPU Case temp is 66C
    This is my main problem in that I can see there being a 5-10C difference between case and core once things have settled, but >30C doesn't quite make sense to me...
    Xtreme Addict unclewebb's Avatar
    Dec 2006
    Cochrane, Canada
    7
    I tend to trust the reported Tcase temperature the least. It can vary depending on motherboard bios calibration but it doesn't seem too far off under load. A 30C difference while running Prime95 Small FFTs with the OEM cooler sounds about right.
    The important one is your core sensors. These are calibrated by Intel and usually very accurate at high temperatures like yours are reporting. They also control thermal throttling so if yours are reporting over 97C then your CPU will be slowing down by cycling the multi down to 12.0 which kills performance.
    These CPUs run hot with the OEM cooler. If a True doesn't get your core temps in line with other users then I'd start asking Intel about an RMA. Poor contact between IHS and cores or an IHS that isn't square doesn't happen too often but it is a possibility.
    Edit: Intel lists the maximum TCase temperature for a 920 at 67.9C. The theory is that keeping TCase below that number should keep your processor within the throttling point which is controlled by the core sensors. Give or take a couple of degrees of sensor error, your results seem to be showing that.
    Sep 2004
    0
    Thanks mate, thats really what I was after. I guess I'll give the TRUE a chance to sort things out for me then before I get too excited. I am aiming to modestly overclock the chip though so if I can't get better temps than that at stock then I will have to look at an RMA I think.
    Cheers
    Xtreme Member Kougar's Avatar
    Jan 2006
    Texas
    0
    If you're getting temps above 90c using stock settings and the stock cooler, then most likely either A) the cooler isn't mounted flush with the CPU or B) no thermal compound was used.
    Intel's pushpin mounting method often doesn't fully engage through the board, it sounds like one or two of the corners didn't mount properly. Try remounting the cooler a few times (you'll need more thermal compound), or a different cooler that mounts properly if ya have one around to try.
    Core i7 980X @ 4.4GHz 1.42v (HT on)
    Gigabyte X58A-UD5 (F5)
    G.Skill Ripjaws 1866MHz CAS 9
    EVGA GTX 480 HydroCopper FTW
    PC Power & Cooling 950W Mrk II
    OCZ Vertex 120GB | Windows 7 64-bit
    Apogee GTZ + MCP655 & Thermochill PA120.3
    Sep 2004
    0
    Quote Originally Posted by Kougar View Post
    These are the same conclusions I came to. As a result I have tried several remounts of the cooler, using AS5 and the grain of rice method each time (I know there are better options available nowadays, but its all I have handy). I have removed the mobo completely to do the remounts, ensuring that each pin has cliped through the board completely so I am 99.99% sure that the cooler is seated as well as it can be.
    I have a TRUE en route so fingers crossed, this coupled with the socket 1366 mount will sort all of my problems. The only issue I found a little strange was that the Tcase reported so differently from the Tcore. Also a bit strange that if Tcore is the more accurate one that Intel sets its Thermal specs of 67.9C from Tcase.
    Xtreme Addict rge's Avatar
    Jun 2007
    30
    Quote Originally Posted by Noids View Post
    Intel has a mathematical formula (posted several times in Real temp thread) that describes the relationship of Tcase max (temp at center of cpu casing/IHS) and Tcore max (temp hottest core) at full TDP load using stock cooler and stock settings, proper testing ambients, etc. But basically at full TDP load, given hottest, ie worst case i920, Tcore should be 32.1C hotter (100C tjmax-67.9Tcase max) than TCase. There is about 5C gradient between Tcore and Tcase at idle, and 20C gradient at moderate loads and up to 32C gradient at max TDP loads, and even higher gradient between Tcore and Tcase when OCing at new full TDP. So if Tcase sensor was calibrated correctly, and located in casing of cpu it would read approximately 5C cooler at idle than core, 20C cooler at mod load, and 32C on max load, assuming stock settings, cooler, certain testing conditions, and worst case/hottest cpu for leakage at loads.
    Tjunction max (temp of hottest DTS sensor in core) is by far the most accurate temp measure, and it is calibrated by intel on per part basis and measures hottest temp in core by scanning and recording multiple sensors in all potential hot spots...which is only accurate way to measure.
    "Tcase" sensor is not even located in correct position (too expensive to place a sensor in cpu casing for mass production, not to mention it would still not be accurate as misses hot spots that multiple core sensors catch). This "tcase" sensor is located between the cores, where it has no chance of accurately measuring tcase or the hot spots. Nevertheless it is calibrated (via generalized average inaccurate calibration, not an accurate per part calibration like tcore directly from intel) and is calibrated much lower than actual temp of location it is at...for a poor attempt at approximating the temperature at casing (where it is not located). Most bioses to accomplish this (follow intel recommendations) and guesstimate a calibration for moderate loads for stock cooler, often being inaccurate and under best cases, in the ball park.
    And look at what happens when one calibrates Tcase for moderate load, when the sensor is in the wrong position. Tcase sensor if accurately measuring its actual location (still in die substrate btwn cores), at moderate load if core measures 70C, Tcase should read ~65C (for duo, who knows with i7) for its true location between cores. But actual Tcase (casing cpu) would be say 50-55C....so bios simply calibrates/subtracts ~10C from Tcase sensor, so it accurately approximates Tcasing at mod load instead of its actual location between cores. But at idle where the gradient is less, the Tcase will now read too low, perhaps even ambient or subambient, both of which are laughable and commonly seen. And this ambient or subambient reading is not an error (though it is wrong), it is the only way to make it semi-accurate under moderate/heavy loads. Not to mention when you put a different cooler or overclock, then this inaccurate bios calibration is made even worse.
    Bottom line like unclewebb said, ignore Tcase, that is what intel does. Or if using Tcase, realize it should read about 15-20C lower than tcore at moderate/heavy loads if properly basterdized to guess a location where it is not located, and that it will then be completely inaccurate at idle and at OCed loads, as it can only be accurate at one exact load setting.
    3770K 4.7 w/1.31 - UD5 z77 - Dom 1866 - Corsair HX850 - Intel 520 240gb - GTX 680 - 26 inch Samsung LCD
    xspc 360 + SR1 280 + HC 680 + EK sup hiflo
    Lian Li A71F
    Dec 2006
    Cochrane, Canada
    7
    Well said rge. Tcase readings have never been accurate and that was the motivation for Intel to go to on die thermal core sensors strategically located at the hottest spots on the core.
    During a full bore test with the heatsink fan turned off, my Core 2 motherboard would report TCase about 9C hotter than the core sensor which is impossible. The center of the CPU can't be hotter than the hottest spot on the core which is the source of the heat. At more modest temperatures, the Tcase sensor is factory calibrated to look a lot more believable but I still wouldn't trust it.
    When you are installing your True I'd pull the CPU and have a good look at it with a straight edge. The OEM cooler is crappy but if all of the push pins are through the board, there might be a problem with how flat the IHS is which is preventing proper contact between the IHS and your heatsink.
    Sep 2004
    0
    Quote Originally Posted by rge View Post
    Cheers Rge, this is precisely what I was looking for. I had noticed on other threads the 5-10C difference, without realising that the difference increases the hotter the core gets. So the approximate 30deg difference I am seeing is not in fact a major discrepancy, simply within normal specs and I am having problems with the cooler. Might have 1 more go playing with it before the TRUE arrives.
    Thanks all.
+ Reply to Thread
