ive never played with it before and never adjusted it but what exacly does the I/O voltage adjustment do? why would you use it/need it?
has somewhat to do with agp bus
| Intel i7 3770K | Custom H2O | Gigabyte z77x-ud5h | 16GB Samsung | GTX680 | 240g Mushkin Deluxe |
-METALLICA-
usually the KX7 has a great I/O voltage...i set mine to default +3.3v but it usually sits around +3.4-+3.45, if i then set it to +3.45v it will sit at +3.5....
so just leave it at default and it should be fine
[Team Green, Abit All The Way
AMD AthlonXP AIUGA 0241 Tbred 1700+ @ 175 x 11, Abit KX7-333, 256Mb PC2700 Samsung @ 175MHz 2-5-3,1T,4Bank, Triplex Ti4200 @ 320/650, D-Link DFE530TX+ 10/100 NIC, Lite-On 16x DVD, Sony 8x4x32 CDRW, Enermax Full Tower w/window,Rounded IDE/FDD Cables, Eagle 350w PSU, Hercules Game Theatre XP, VideoLogic DigiTheatre LC 5.1
3D Mark Score : 13529#5 AMD/Ti4200 Under 1850Mhz
Visit InfinityComputer.com! <-------------
the I/O voltage selection allows higher clock speeds to be reached when overclocking your AGP Card.
Set me free.
A64 3200 @ 2250mhz (10x225 @ 1.6v) | Chaintech ZNF3-150 | 2x 256mb Corsair 3200LL TwinX @ 2.5-2-2-7-12-16 | 256mb Albatron 5950 VIVO | 80gb DiamondMax 9 | Pioneer 106 | APC 2200RMI3U UPS
thanks im used to running epox..... they call it "agp voltage" but with the bandwidth this kx7 has abit can call it anything they want
My personal test's on my KR7A showed me that upping the IO voltage from 3.55 to 3.65 resulled in a Vcore increase of +0.1 and the memory volts of my R8500 when't up from 3.30 to 3.40
Some people Vmod their board to give an higher IO voltage. On my next board I'm going to do the same, as it's an easier way to get your AGP card to clock higher without having to solder on the card !!
To bad I didn't know this earlier when I had my mobo Vmodded
didn't know to much about Vmodding a year ago, and asked a guy to Vmod my bord doing Vcore, Vddr & Vio. He said nobody has asked for a Vio mod, and that it doesn't do much for your system. So he talked me out of it, (that and he had never done it )
Boy was he wrong
Life goes by quickly--so should your stationwagon
I/O has helped me on my KX7 board, when i get around 180Mhz my AGP card was crapping out in 3dmark, it could bench sandra all day and same as prime, but i raised the I/O voltage and now it is all fine.
