+ Reply to Thread
Results 1 to 8 of 8
Thread: Replacement thermal pads for EK FC vga blocks?
    Xtreme Member dubtown's Avatar
    Feb 2008
    florida
    0
    can anyone point me in the right direction...
    thanks
    Chasing After Diety NaeKuh's Avatar
    Jan 2007
    Absolutely Speachless :O
    1
    Quote Originally Posted by dubtown View Post
    thanks
    explain pads...
    u mean that gray or white thing that sits ontop of memory components?
    http://www.koolance.com/water-coolin...product_id=580
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    44
    Petra's has thermal pads
    The Cardboard Master
    And put that GPU to work too! Fold for XS
    Main PC: Intel Core-i7 2600k @ 4.5GHz, 8GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 7 Pro x64, water - ONLINE
    Office PC: Intel C2D e8400 @ 3.0GHz, 4GB DDR2-800, GeForce GTS 250, Win 7 Pro x64, air - ONLINE
    Dedicated: DP Intel Xeon LV Sossaman @ 2GHz, 4GB DDR2-400 ECC, Win XP Pro, air - ONLINE
    Family PC: Intel C2D e8500 @ 3.2GHz, 3GB DDR2-667, Radeon X1300, Win 7 Home x64, air - ONLINE
    Feb 2008
    florida
    0
    the tiny ones for the voltage regulators
    Jan 2007
    1
    u can use the koolance ones.
    or u can get the ones for EK that petras has thats precut.
    However i recomend the koolance one as it comes in 2 different thickness, and you get a lot for future applications.
    Feb 2008
    florida
    0
    cool... thanks... order placed
    Jan 2007
    1
    dub b4 someone newbs you and say you got the wrong one.
    90% of the thermal pads used by us are made by the same OEM basically. Dow chemicals.
    Im 100% sure the .5mm thick one will work for what you need on your EK block. the 1mm thick one might be too thick.
    .5mm pad has 2 protective sheets u need to peal, the 1mm one is only single side protective.
    Xtreme Addict Eddy_EK's Avatar
    Mar 2005
    Slovenia - EU
    0
    Hi!
    It is a little funny, why don't EK product users contact EK support.
    The only question is for which block do you need, as you might need different thickness
    Quote Originally Posted by creidiki
    EKs are like waterblock pr0n
+ Reply to Thread
