OK,
I got a small problem and I don't exactly know where to locate it so I'm asking you experts for some help.
Here's the deal :
I bought a Feser triple rad about 2 weeks ago and received it last week.
I'm planning on building it into a Lian Li PC-A70B, which I purchased some time ago (already had it powder coated).
Along with the case, I bought the matching T703B top panel, which accommodates 3 x 120mm fan holes, so I can mount the radiator there.
After opening the package of the Feser, I mounted 3 Scythe S-Flex fans to it with the provided short screws from Feser.
After that was done, I placed the top panel onto the fan/radiator.
It was then that I noticed that it didn't match.
For some reason, the fans didn't align with the holes of the Lian Li top panel.
I was checking a LC worklog thread from member aCt! here http://www.xtremesystems.org/forums/...d.php?t=223396
and I noticed he had no problems fitting the Feser triple rad onto a Lian Li T70103B top panel.
That top panel is for the PC-A7010B case, which is more or less the same as the PC-A70B (the dimensions of both cases should be more or less the same),
so I presume the dimensions of the provided blow and fan holes of both the T703B top panel (mine) and T70103B top panel (his) should be the same too.
aCt! kindly responded to my questions (again, thanks for that ), and knowing that Feser had 2 revisions of the Tripple rad. One with 17mm fan spacing and the newer ones (released after May 2008) with 15mm fan spacing.
I checked Feser's site and downloaded the PDF files of both revisions of the triple rad.
The problem is that I don't at which distance they measured the fan spacing.
Is it from the edge of the holes, or from the center of each hole. Confusing.
So I measured them myself, using a digital caliper and I took some pics of it.
The first pic is while measuring the distance between the Feser fan holes starting from the edge (picture will make it clearer for you).
I measured approx. 15.08 mm.
Picture #2 show measuring the distance between the Feser fan holes, from the center of the holes (more or less).
I measured 16.97 mm
Picture #3 shows measuring the distance between the Lian Li top panel fan holes, starting from the edge.
Picture #4 shows measuring the distance between the Lian Li top panel fan holes, starting from the center of the holes (more or less).
Picture #5 shows the panel mounted on the Feser rad. As you can see (maybe not that clear) the holes don't align.
So my question now is :
- Can the owners of the Feser triple rads measure the distances between the fan holes, like I did?
- Not being sure on how Feser measures the distances between the fan holes, but would it be possible that I received the older revision of the radiator (17mm fan spacing) and not the newer ones with 15mm spacing?
I'm not sure what I'm gonna do now.
I'll be contacting the shop I bought the radiator from tomorrow, hoping they can provide my more info.
Any help or suggestions would be appreciated.
