Had this board for over a year now but i've never been able to get it above 3ghz! , Here are my settings currently
ASRock Penryn1600SLI-110dB
Q6600 Core 2 Quad Kentsfield B Stepping , Rev G0
8GB 800DDR2
8GB 800DDR2
Forgot the bios info!
CPU FREQ - 333
PCIE FREQ - 101
DRAM - AUTO
MEM TIMINGS - AUTO
HYPER TRANSPORT MHZ [ 1000MHZ ]
CPU VOLTAGE - 1.41875V
DRAM VOLTAGE - 2.08 V
CHIPSET VOLTAGE - 1.382V
VTT - 1.42V
GTLREF VOLT - [ HIGH ]
HALT STATE - DISABLED
MAX CPUID VALUE LIMIT - DISABLED
CPU THERMAL THROTTLE - DISABLED
SPEED STEP - DISABLED
Noone?
Nobody has an asrock penryn then , bad for me lol
Massive Indy Games & Retro Remakes Archive
+ This member has Autism(aspergers) & OCD
I don't have that board, chances are its your mobo holding you back. That mobo is pretty low end, getting a Q6600 above 3GHz with 8GB of ram will need something better.
BTW if possible lower that VTT (when at 3GHz) about 1.3VTT should be plenty.
