Results 1 to 7 of 7
Thread: Possible cooling solutions to get 3 4890's to fit on the bloodrage!?
    Jul 2007
    Any thoughts guys?
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    get an HR03 and use it on the top card then get liquid for the other 2, or find a single slot liquid block for the top card
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Xtreme Mentor
    Sep 2007
    Dallas
    Go water cooling and use the Koolance blocks.
    CPUID http://valid.canardpc.com/show_oc.php?id=484051
    http://valid.canardpc.com/show_oc.php?id=554982
    New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
    4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
    Desk Build
    FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
    W/C System
    (CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
    Assistant Administrator systemviper's Avatar
    Nov 2007
    Newtown, CT
    Quote Originally Posted by Utnorris View Post
    Damn he has all the answers frght from the bowl
    HWbot - Team: XtremeSystems
    XS cruncher - Team: XtremeSystems
    OCN Feedback
    HEAT
    *** Being kind is sometimes better then being right.
    Jul 2007
    hmmmm are the koolance blocks single slot?
    Xtreme Mentor
    Sep 2007
    Dallas
    If for some reason they are not, which I believe they are, there is always the Aqua Computer models. I just like the Koolance model better since it has ports on both sides out of the box.
    Desk Build
    W/C System
    Jul 2007
    any links to this stuff? and is the bloodrage 16x16x8? or 16x8x8?
