Just wondering what BIOS is everyone using. I'm on P07 and gotta say its not great as my default (P03) on mobo. I just cant reach OC's as high as i could before
P07 because I have a DO 920
Asus P9X79PRO, EK MOSFET H20,
3930K @ 4.8 Full Nickel HF Supreme
EVGA classified GTX 780 Hydro copper 4 x 4gb Mushkin 1600 @1.5v
2 X 250 GB Samsung evo RO, 3 x 640 WD Blacks Storage, Corsair AX1200, Phobya Nova 1080, Fesser 120,with GT 1850's
Was on P07, now on P06 .....don't really see a difference but more testing would be needed on P07. Has anyone checked out the G21 & G22??
____________________________________________
More & more very expensive, quickly obsolete parts!!
Nope, Im scared of beta BIOS and love board too much. Heh, maybe I'll try.. didnt tried P03 (mobo was with P04). My max OC was 4,2GHz .. can't reach higher, cause of cooling (90°C CPU..ouch).
Using P07, haven't tried any other.. plus its working. When I get some better cooling, I'll try more... and better rams, jeez those sux so much (G.Skill NQ - never again).
I´m still using P03 and it runs great (expect of the fact, that i can´t boot with an USB Drive connected with my OC Settings)
System #1:
i7 975 for bench, W3540 @ 4,4 Ghz HT On, Asus P6X58 Premium, 3x2048 Corsair Dominator 2000CL7, Sapphire 5970 @ stock, Corsair HX1000, 1xOCZ Vertex2 120GB, 3x1TB WD Green
Cooled by:
Loop 1: Watercool HK rev 3.0, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Phobya Fans @ 5V Pull
Loop 2: EK 5970 Nickle, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Phobya Fans @ 5V Pull
Loop 3: EK Asus NB/SB, Mips Asus Mosfet 1 + 2, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.2 /w Phobya Fans @ 5V Pull
4,6Ghz (21x220) 1,42Vcore with Single Stage (HT enabled)
http://img402.imageshack.us/img402/1251/83962063.jpg
AMD @ testing
X4 955, Asus Crosshair III, same Rams as on Intel Setup, Sapphire 4870X2 @ Stock, PC Power&Cooling 910W
Using P07 at 4.2Ghz
P06 because there isn't a need for me to go to P07. 4.2Ghz without sweating.
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Desk Build
FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
W/C System
(CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
I am using G19a all other bios will not let me raise my multiplier higher than 24 on the 965.
Thermaltake Armor+
Foxconn Bloodrage
i7 965
Gskill 2000 7 8 7 2000
Evga gtx295 quad sli
Custom watercooled
Ultra 1600w psu
Velocirapror 300
Vista64
latest vantage 43200
P06, because with P07 i can't make any overclock with my 920 C0/C1.
P06 cause thats what they told me to use, lol.
P06, just check my DO CPUID in sig and you will see it works great.
Desk Build
W/C System
P07 & G25, it's time again to play
testing G22 now
i7 Rigs
Mobo:EVGA Classified/Foxconn BR
CPU:W3540/i7 920(D0)
RAM: Dominator GT 2000 cl7/Patriot DDR3-2000 cl8
GPU:Sapphire 4870x2/XFX 4890/ GTX 260 tri-sli
Lappy:
Late 2008 "Unibody" MBP 2.4 GHZ(with OCZ Vertex 250GB)
I am on P06 anything works fine.
still testing max Blck was 211 atm.
Now i am at 195 x21 , Vcore 1,32V, Ram 1,67V, Vtt 1,28 running Prime since 6 hours now.
These values are measured at the pads, i noticed that the BR dont reacts on +40, +60mV on Vtt.
I mean i still measur 1,11V than.
Beside from +0,02V on Rams the reading are absolute correct with Bios and CPU-Z 1.51
http://valid.canardpc.com/show_oc.php?id=558035
i'm using P07 at the moment, but wondering about going back to P06... was a bit "easier" to OC with...
i can boot my BR rev1.1 and i920 C0 @ 211 bclk on both bios.
i can reach 215 also (with aegis), and it seems to be a bit more "stable"... (crashes a little later in super pi )
but i keep a 200 bclk for the 24/7 which is rather good i guess.
have tried P04 : ok but not wonderful
and G13: same thing
in my opinion the best are P06 or 7 for C0 steppings
and P07 for D0s
doctor pepper's desk
EVGA P55 FTW | i5 650 @ 4GHz | 4Gb Corsair Dominator DDR3-1600 XMS3 | XFX 4870 1Gb | Corsair X32 | Samsung SpinPoint F1 - 320Go | Fractal Design Newton R2 650W | Samsung P2450H | Microsoft Laser Desktop 7000 | JBL Spyro Black
AirCooling: Prolimatech Mega Shadow | Xigmatek Bifrost | Fractal Design SATA Cluster Box | Fractal Design 2x120mm, 2x140mm and 1x92mm
Cosmos-S
Foxconn BloodRage Rev1.1 Bios P07 | i7 920 D0 @ 4,629GHz max & 4,3GHz stable | 6Gb Corsair Dominator DDR3-1600 | XFX 5870 | Sonar X-Fi | Intel X25-M 80 Go PostVille | Samsung SpinPoint F1 - 1To | Corsair HX620W | CoolerMaster Cosmos S | Samsung T240 | Logitech MX-5500 & Z-2300
Watercooling: Laing DDC + plexi top and tank | CPU - HK 1366 rev 3.0 LT | GPU - EK Water Blocks EK FC5870 V2 - Acétal Nickel | MB - Foxconn's original | HDD - HK SilentStar HD-Single rev 2.0 | radiator - 3x120mm | tubing - High Flex 10/16mm | red PrimoChill ICE coolant
Tested G22. Total bust for me with a 920 D0. Would not boot into Windows no matter what I tried. None of my OC's worked that were fine on P07. Post would hang at "update success" with post code 96 and just stay there. I was trying to see if G22 would get BR closer to the performance of my Classified using the same chip. I'll wait for a new bios before trying again.
tripgood
Big hardware pile
Thanks for the info, I was tempted to try G22Tested G22. Total bust for me with a 920 D0. Would not boot into Windows no matter what I tried. None of my OC's worked that were fine on P07. Post would hang at "update success" with post code 96 and just stay there. I was trying to see if G22 would get BR closer to the performance of my Classified using the same chip. I'll wait for a new bios before trying again.
Im on P07 now and all is fine for 24/7, DO 21 x 200 Bclk 4.2 with 1.28vcore under load.
Max Bclk seems to be 222 for me on P07 so new Bios is definately needed to get closer to Classified speeds.
g22 bios
i7 Rigs
Lappy:
[QUOTEg22 bios][/QUOTE]
Nice clocks is it Prime stable ? What cooling are you using ?
Looks like you may have a bad bios flash Tripgood.
i7 Rigs
Lappy:
