Results 1 to 12 of 12
Thread: AM3 cpu performance across 3 motherboards comparison
    Jun 2005
    NYC
    Exclamation AM3 cpu performance across 3 motherboards comparison
    im gonna be testing cpu performane on the 3 mb that i have
    test setup
    asus m4a79-t
    msi gd-70
    giga ud5p
    kingston 3x1gig ddr 2000
    wd raptorx 150 gb
    1 4870x2
    1200watt coolmax psu
    win xp sp2
    9.1 cats
    latest bios available to me at the time of testing although i wil rerun test in the future with different bios's
    *edit*
    im going to test 3.7 ghz cpu and 3 different nb speeds
    memory timing will be set @ 7-7-7-21-33 across all three boards so all settings will be the same.
    test to be ran
    pi
    wprime
    3d 06 cpu test
    everest
    sandra
    cinebench 32 bit
    Amd Nvidia/Ati -3dmark06 scorebord revisted
    asus L1N64-ws or /b depending on bios chip
    4x1gig 8500 gkill bpk
    2x opteron 8224 @ 3.8ghz
    http://www.xtremesystems.org/forums/...&postcount=236
    vga= 8800gt
    winxp pro
    custom chiller -31 water
    2x dtek fuzions
    bix3-with x3panaflo hi output
    antec 850 quattro
    heat under msimax abitmax and dfimax
    Jun 2005
    NYC
    gigabyte ga-ma790fxt-ud5p 3.7ghz cpu 2.6nb
    gigabyte ga-ma790fxt-ud5p 3.7ghz cpu 2.8nb
    gigabyte ga-ma790fxt-ud5p 3.7ghz cpu 3.0nb
    vga= 8800gt
    winxp pro
    2x dtek fuzions
    antec 850 quattro
    Xtreme Enthusiast TheBlueChanell's Avatar
    Dec 2006
    Awesome idea MSI. I think it's really going to come down to the nitty gritty cause these 3 motherboards are pretty close in comparison.
    EDIT: Sorry if I snagged one of your reserved spots.
    Main: 900D - Prime 1000T - Asus Crosshair VI Extreme - R7 1700X @ 4.0ghz - RX Vega 64? - 32GB DDR4 3466 - 1TB 960 Pro -
    --- XSPC AX360 x3 - HK IV Pro - HK RX480 - HK 200 D5 - BP Compression ---
    HTPC: 250D - Prime 850T - Gigabyte G1 ITX - i7 6700K @ 4.5ghz - GTX 1080 Ti - 16GB 3200 - 1TB 960 Pro -
    --- ST30 x UT60 - Kyros HF - KryoGraphics 1080 - HK100 DDC - Monsoon Compression ---
    HV01: Define XL R2 - Prime 1200P - Asus Zenith Extreme - TR 1950X - RX580CF - 128GB DDR4 ECC - 512GB 960P - 4x 2TB RE
    HV02: Node 804 - Prime 850T - SuperMicro X1SSH - E3-1230 v6 - Vega FE - 64GB ECC - 512GB 960 Pro - 4x 6TB Gold -
    Jun 2005
    NYC
    reserved2
    70sec post rule sucks lol
    vga= 8800gt
    winxp pro
    2x dtek fuzions
    antec 850 quattro
    Jun 2005
    NYC
    reserve 3
    vga= 8800gt
    winxp pro
    2x dtek fuzions
    antec 850 quattro
    Feb 2009
    Looking forward to those results even if features generally mean more to my purchasing decision of a mainboard than it being 1 or 2% faster than the competition.
    Jun 2005
    NYC
    to be continued
    vga= 8800gt
    winxp pro
    2x dtek fuzions
    antec 850 quattro
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    3.7GHz was the max stable OC air on this Giga MB?
    ROG Power PCs - Intel and AMD
    Jun 2005
    NYC
    nah i knew i was gonna run high nb so i chose that speed to keep heat in check which still was a issue for the last tests
    vga= 8800gt
    winxp pro
    2x dtek fuzions
    antec 850 quattro
    May 2008
    Czech republic
    i hope, ASUS M4 will be winner ...Its my tip.
    Xtreme Cruncher Russ_64's Avatar
    Aug 2005
    London, UK
    What AM3 chip do you have - ES? do you know if it is 945 or 955?
    Hope you can add a DFI when it is available ..............
    Asus Maximus VIII Ranger Z170 : Core i5-6600K : EVGA RTX2080 XC : 16Gb Corsair Vengeance DDR4-3200 : 256Gb Crucial MX500 : Corsair H100i : PCP&C 750w 60A : CM Cosmos S : Windows 10 x64
    Asus Z8NA-D6 : Dual Xeon E5645 : 24Gb DDR3-1333 ECC : MSI GTX470 : 120Gb Samsung EVO 840 : 1TB HDD : PCP&C 750w 60A : CM Stacker : DD MC-TDX, EK-FC470, RX240+RX120, D5 X-Top, BayRes : VMware ESXi 6.7.0 - VM's - WCG crunchers x 5 (Ubuntu 18.04 LTS), Mint 19, Windows 10 Insider Preview
    Sophos XG 17.5.3 running on GA-Z97-Wifi : Core i3 : 8Gb DDR3-1600 : 120Gb SSD : Corsair H80
    BenQ GW2765, Aten 4-port KVM, Asustor AS5002 4Tb NAS, Belkin 1500va UPS, Sky Fibre Max 80/20Mbps
    Jul 2002
    Derbyshire. UK
    Can we please have an update on this? ANYONE would think the forums have been closed or something!
    New Rig
    ► AMD 720BE @ 3.2GHz Stable
    ► Corsair 4gb DDR3 Twin3X
    ► Gigabyte A-MA790FXT-UD5P
    ► Radeon HD 4870 1024MB GDDR5
    ► Corsair HX 620W
    ► Western Digital Caviar BE
    ► Sunbeam Core Contact Freezer
    ► Samsung T240 HD 24" LCD (x2 Soon)
    Old Rig
    ● DFI Lanparty nf4 SLI-DR
    ● AMD Opteron 146 (CACJE) @ 2.6Ghz (Now @ 2.2Ghz for Stability
    ● 1GB TwinMOS -bh5 @ 260MHz (Now @ 220Mhz for Stability)
    ● 2 x 120gb WD SE HDD's - IDE
    ● 2 x Pioneer 109 DVD-R/W - IDE
    ● Hiper Type R PSU - 580w
    ● 128mb MSI ATI GFX
    ● Will be cooled by Mach II when it's fixed.
