OCN2
Results 1 to 18 of 18
Thread: Core i7 system for under $1400?
    Feb 2005
    USA
    I'm trying to upgrade my dinosaur AMD Opteron 148 system and base on the brief research I did, here is a list of gear that I came up with from newegg, I'll be using it mainly for video editing and photoshop, and a little gaming once awhile. As far as memory goes...please let me know if I made the right choices and if you would change any thing from the list? I would like to run 12GB of ram if not I could settle on 6GB kit.
    Intel Core i7 920 $279.99
    Asus P6T Deluxe V2 $289.99
    OCZ Platinum 6GB (3 x2GB) DDR3 1600 $109.99/ea (x2 = 12GB $219.98)
    Antec Nine Hundred Black Steel ATX Mid tower $109.99
    PC Power & Cooling S75QB 750W PSU SLI Certified: $119.99
    Samsung 22X DVD Burner $24.99
    EVGA GTX 285 1GB video card $354.99
    total: $1399.92.
    note: I already have several hard drives that I can use so it's not included in the list.
    Core i7 920 D0 3844A717 4.40Ghz HT on @1.36v (LinX/Prime/3D stable), Corsair 850W, 12GB OCZ Platinum 1600, P6T Deluxe V2, EVGA GTX 285 SS, OCZ Vortex SSD 30GB x3 RAID0, HAF 932.
    Water Cooling Setup: XSPC RX360, MCP355 + XSPC Res Top, Swiftech GTZ, 1/2" Tygon, Scythe S-Flex SFF21F push, 20mm yateloon D12SL-12C pull.
    Opteron 148 CABNE 0528 GPMW 3.1Ghz @1.6v Prime Stable. Westy 37" LVM-37W3, DFI Venus 975, 2GB TeamX Cronus Micron, GSkill HZ, Sapphire X1900XTX, Zippy 700W, X-Fi Xtrememusic, 36GB Raptors x2 @Raid-0.
    WC Setup: PA120.3 +Shroud, MCP655, STORM, MCW60, 1/2" Tygon, mini res, Yate Loon.
    Engineering The Xtreme
    Feb 2007
    MA, USA
    the antec 900 is C-Rappy lol.... do yourself a favor and get a CM690 or a HAF932 (the two best budget cases around IMO)
    Apr 2005
    I would go with 6gb ram and upgrade to a GTX 295. Unless you're planning to go SLI later with 2 285's.
    All systems sold. Will be back after Sandy Bridge!
    Feb 2005
    USA
    K, i'll look into CM690 or HAF932 for the case then.
    Quote Originally Posted by clayton View Post
    Any reason why 6GB ram instead of 12GB? I don't game much, the only game that I play once awhile is the BF2 or BF2142, that's why I do not need the best video card or anything, I don't plan on running SLI either.
    Nov 2005
    Quote Originally Posted by ben805 View Post
    I bought the CM690 at the refurbished store of CM at half the price. The case looks like new!!
    Jun 2004
    south of heaven
    I have exactly the system you outlined except I bought an Antec 1200 (Newegg deal). I'm completely satisfied with the setup. It pushes games at 1920 x 1200 with no effort. I would just recommend to get the 2GB version of the GTX285. It would be better long term purchase.
    Asus P4C800ED P-M 730@2.8 7700Cu
    2X1GB OCZ - ATI X800XT AIW - OCZ PS 520W
    Sep 2007
    What will you be doing that requires 12GB of ram?
    Also, for that price, I'd recommend going with the Corsair 850TX PSU. It's $100 after rebate from Newegg.
    CPU: i7 920 C0 @ 3.8 GHz HT, 1.25v
    Cooling: Thermalright Ultra-120 Extreme
    Motherboard: Gigabyte EX58-UD5 w/ F9m BIOS
    Memory: 6GB G.Skill DDR3 1600
    Video: HIS 6950 2GB
    Hard Drives: WD Black 640GB, 2x WD Green 1TB
    Power Supply: Corsair 850TX
    Case: Antec P180B
    Monitor: 30" Dell U3011 H-IPS
    Peripherals: Logitech Illuminated + G7 | Sidewinder X4
    Sound: Auzentech X-Fi Forte | Audio-Technica AD700 | Logitech Z-2300
    OS: Windows 7 Professional x64
    Feb 2005
    USA
    Converting RAW files from my Canon 5D Mark II (21MP) camera is the main reason why I think having 12GB of RAM would help, each RAW file is about 22~28MB depending on what ISO i use, right now it takes about 1 1/2hr to convert about 580 RAW files. Then post processing these files in Adobe Photoshop CS4 or Lightroom 2.3 takes forever with my current machine....
    If 6GB is sufficient then I'll stick with it, anything to consider is if or when I decided to overclock this system, would 6GB allow higher overclock as well?
    Aug 2005
    Washington
    I'm in Web Deisgn, but I have done a fair amount of graphic work too. I haven't really used many RAW files at the same time, but I have worked with very large vector files. For me, 6gb is enough, but 12gb would probably be slightly better. It is a huge step up from 4gb though, the difference is noticeable on CS4.
    The main thing keeping me from 12gb is I don't think it is really all the needed and it will make OCing harder.
    Sep 2007
    I pretty much do exactly the same thing, only I have a 40D. 6GB is enough if you ask me.
    Video: HIS 6950 2GB
    Case: Antec P180B
    Xtremely Hot Sauce
    Sep 2007
    New York
    What about dropping the GTX285? I think CS4 is accelerated by HD4800s as well, and a 4830, while not as fast, would be much less expensive. Other than that, what about the DFI LP DK T3eH6?
    http://kb.adobe.com/selfservice/view...5445&sliceId=1
    What about a G92 512MB or 1GB card? Decent gaming, good in CS4.
    My toys:
    Asus Sabertooth X58 | Core i7-950 (D0) | CM Hyper 212+ | G.Skill Sniper LV 12GB DDR3-1600 CL9 | GeForce GTX 670-2048MB | OCZ Agility 4 512GB, WD Raptor 150GB x 3 (RAID0), WD Black 1TB x 2 (RAID0) | XFX 650W CAH9 | Lian-Li PC-9F | Win 7 Pro x86-64
    Gigabyte EX58-UD3R | Core i7-920 (D0) | Stock HSF | G.Skill Sniper LV 4GB DDR3-1600 CL9 | Radeon HD 2600 Pro 512MB | WD Caviar 80GB IDE, 4TB x 2 (RAID5) | Corsair TX750 | XClio 188AF | Win 7 Pro x86-64
    Dell Dimension 8400 | Pentium 4 530 HT (E0) | Stock HSF | 1.5GB DDR2-400 CL3 | GeForce 8800 GT 256MB | WD Caviar 160GB SATA | Stock PSU | (Broken) Stock Case | Win Vista HP x86
    Little Dot DAC_I | Little Dot MK IV | Beyerdynamic DT-880 Premium (600 Ω) | TEAC AG-H300 MkIII | Polk Audio Monitor 5 Series 2's
    Feb 2007
    MA, USA
    4870's are beasts in cs4 lol, or at least my dad (who is a professional photographer) can zoom and pan in CS4 while working on an ~800mb file with ease
    Sep 2008
    The extra 6 GB is $109 more so if you are ok with that, then get it. I have 12 GB. That said, 6 GB probably OCs better, so if you plan on OCing the ram, then 6 GB may be better. My Ram isn't OCed.
    I have the HAF 932 now and love it. I used to have the Antec 900 and it was a good case, but a bit small. The 932 has tons of room. I recommend it.
    Feb 2005
    USA
    Quote Originally Posted by PC_User View Post
    I still have my 40D as backup, my current system with only 2GB handle 40D files just fine. But the 5D Mark 2 is a whole different beast!
    Feb 2005
    USA
    What after market heatsink/cooler do you guys recommend for the Core i7 920? I prefer to stick with air cooling.
    As for video card, I'm still using the X1900XTX....it's more than enough for me to game BF2, I guess it will do ok with CS4, etc as well?
    Feb 2007
    MA, USA
    I've just installed the coolermaster V8 in an i7 system and its definitely a really nice cooler. the tip-top is the TRUE as always
    Sep 2007
    Thermalright Ultra Extreme 120 RT 1366.
    A bit of an older card, but should be able to handle CS4 just fine. If you plan on playing the latest games, you'll need to upgrade.
    Video: HIS 6950 2GB
    Case: Antec P180B
  18. #18
    Jun 2006
    [QUOTE=ben805;3741180]What after market heatsink/cooler do you guys recommend for the Core i7 920? I prefer to stick with air cooling.
    Noctua NH-U12P
    CPU------------Intel Core i7 920 D0 @ 3.8GHZ Vcore: 1.2v with vdroop
    Motherboard------EVGA X58 Classified E760
    Memory----------3x2GB Patriot Viper Extreme 1600MHZ DDR3 8-8-8-24-74-1T
    Graphics Card-----Sapphire HD 5870
    Hard Drive--------Western Digital Caviar Black 640GB
    Sound-------Onboard
    Power Supply-----Thermaltake Black Widow 850W
    Case-------------Thermaltake Xaser Vi
    CPU cooling-----Noctua NH-U12P Push/Pull
    OS---------------Win7 Pro x64
    Monitor-----------24" Viewsonic VX2433WM
