OCN2
Results 1 to 6 of 6
Thread: Are there any 5.25" Bay LCD/LED Clocks?
    Dec 2008
    I have a tj07 and want a nice cool clock to fit into a bay but also has nice beveling with no buttons so it looks nice in the case...
    but i can't find anything any ideas?
    I thought about hard modding a normal lcd clock in the case and then some how modding it so the bay cover is the front of the clock but that's a bit too much work for this i think so what do you guys think?
    Dec 2008
    bump?
    Apr 2008
    Canada, by the mountains
    Tho pricey, it looks like you can display time (in all sorts of colours) on a Matrix Typhoon
    http://www.bit-tech.net/modding/2008...hoon-display/1
    Time is an illusion. Lunchtime, doubly so. Douglas Adams
    QX9650 @ 3825mhz CoolIT FZone
    2x HD3870X2 @ 845/946mhz air
    Asus Maximus Formula 0907
    2x2048mb OCZ Reaper 8500
    2x Raptor 150G Raid0; 'Cuda 1000G
    1200W Thermaltake
    xFi Extreme Gamer/ Z-5500
    Vista Ult. 64
    Cosmos 1000
    30" NEC
    Aug 2007
    EU
    don't know? maybe You have looked NZXT products already, they have one,
    NZXT Sentry LX ( http://www.nzxt.com/products/sentry_lx/ ) see the product inf ..
    also lots of different reviews can be ''google'd"
    anyway, it is not only a clock and unfortunately it needs 2 5.25'' bays to fit
    OK, not my option to argue about design and etc stuff like this, just thought .. may be this helps
    BTW i have it installed to CM Haf'932 and it fits to this concept
    Attached Images Attached Images
    Maximus Extreme / Air // E8400 // Noctua NH-C12P
    Asus 8800 ULTRA /Stock Air/
    G.SKILL F3-10600CL8D-2GBHK
    Tagan TG700-BZ // Antec P182 B
    Rampage Extreme / Air // QX9650 // True120 Black
    A-Data DDR3-1600G 3x2gb kit (using 2 modules 2x2b)
    ((CellShock (MSC CS3222580) ) dead
    Sapphire HD 4870x2 (single) stock Air
    Be Quiet! Dark Power Pro 1KW // HAF'932
    Feb 2009
    South West Ohio
    Quote Originally Posted by i43 View Post
    I'd say look into this also, it is very useful and a great product, if you can deal with a little more than a clock. It has a very clean look to it imo and would easily do exactly what you're lookin for and a little more
    dual bay setup alphacool dual slot bay http://www.performance-pcs.com/catal...ducts_id=20600
    i am looking for a good dual bay slot design lcd display so i can post my temp probes and such
