Lookin to buy a ssd for os and some apps
Whats the top 60-80gb ssds?
I dont want something crappy but I cant spend a ton either.
Should i just wait a few months?
A 60GB OCZ Vertex would probably be in your price range. http://www.newegg.com/Product/Produc...=vertex%2060gb
Vertex and Intel X25's are the only SSD's out that are considered "good". The Intels are more expensive though.
i7 3970X @ 4500MHz 1.28v
Asus Rampage IV Extreme
4x4GB Corsair Dominator GT 2133MHz 9-11-10-27
Gigabyte Windforce 7970 OC 3-way Crossfire
Windows 7 Ultimate x64
HK 3.0-MCP655-Phobya 400mm rad
Corsair AX1200i
Sandisk Exrtreme 240GB
3x2TB WD Greens for storage
TT Armor VA8003SWA
I'd go with intel but the price on the 60g vertex is just begging you to get two and raid it.
i7 940/Rampage 2 Extreme/Corsair 6g Dominator/Corsair HX100W/GTX 580/SSD
Holy hell thats expensive.
Ill wait lol
u could get the samsung slc http://www.newegg.com/Product/Produc...82E16820147056 but u will need a mini sata power addapter, its the best IMO under $300, and its cheaper and faster than the vertex
5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
+1 for the Vertex
If you really want it now, buy the 30Gb version and test it and see how it goes.
the peak output isnt high but its slc and has fast small reads and writes and has high iops
if i was going to get an ssd for system use i would get that, affter the shuttering on the v2 as a primary os drive im not going with anything jmicron even if it has cashe. if u want a 2.5" the corsair is worth the money but its 128GB only. i use my v2 for vhd files with hyperV and its great for that but primary os is bad so slc or samsung controller (or both)
sorry for being really clueless, is what u refer to something here, maybe?
http://www.newegg.com/Product/Produc...e=&srchInDesc=
Also, I can't find this product on Samsung's site, anyone know why?
