Results 1 to 22 of 22
Thread: 9800 GTX Repairable?
    Mar 2008
    Pennsylvania
    I recently volt modded my 9800 GTX. It seemed fine at about 1.3V but after about 3 hours it went up in flames.
    I'm wondering if there is any chance of being able to repair it.
    V3 Xeons coming soon!
    Nov 2005
    New Hampshire
    Brings out Bugle.. Plays Taps..
    The XS WCG team needs your support.
    A good project with good goals.
    Come join us,get that warm fuzzy feeling that you've done something good for mankind.
    Quote Originally Posted by Frisch View Post
    If you have lost faith in humanity, then hold a newborn in your hands.
    Admin
    Mar 2003
    North Texas
    WOW!!! I'm thinking that one is beyond repair.
    UNDER THE ICE .com
    Phase Change Cooling
    is the remedy
    IT Engineer in the making
    Jun 2003
    Former Kingdom of Bavaria
    First, clean it up to give us a better view of the situation. As long as it looks like the card attended a barbecue, we won't be able to tell you much.
    Just that much: Just because it looks bad, doesn't mean that a repair is impossible. The first problem that you'll have, most likely though, is where to get the replacement part(s).
    Xtreme Mentor dengyong's Avatar
    Nov 2006
    A great place again
    I'd like to bail you out, but I gotta say...
    it's dead.
    Mar 2008
    Pennsylvania
    Alright, thanks every one. Now I have a reason to buy a 4890 in a couple weeks.
    Xtreme Cruncher
    Aug 2008
    Williamsport, PA
    There is a repair part to fix exactly this problem in newegg.com for 179.99
    Q9300 [Crunch] / XFX GTX285 [Fold] / EVGA 750i
    Two 250GB 7200 / 4GB XMS2 800 / 1Kw XPS PSU / Freezer Pro 7
    10,797 3DMark Vantage / Scythe 120mm Case fans / Vista U. 64
    PS3 - 700 Work Units and going strong!, XPS 720 H2C Case
    Crunching 24/7 on Q9300....might upgrade to an i7
    Mar 2008
    Canada
    Quote Originally Posted by GTSRboy View Post
    It is almost the price of the card itself.
    Xtreme Cruncher
    Aug 2008
    Williamsport, PA
    Quote Originally Posted by Sn@ke:~ View Post
    The repair parts is a 9800GTX! (i think they are 180 ish now)
    Xtreme Legend
    Jan 2003
    Stuttgart, Germany
    Quote Originally Posted by thebluemeanie1 View Post
    yes
    Xtreme Legend
    Nov 2002
    Sweden
    How did you mod it?
    How did you measure the voltage?
    Cooling?
    "In mild doses, ethylene produces states of euphoria, associated with stimulus
    to the pleasure centres of the human brain."
    Intel benching: 3DMark Vantage: E69642, P37253, H30363, X22138
    Swedish Overclocking Champion 2006 - Celeron Mobile 1400 @ 4243MHz - 203%
    Mar 2008
    Pennsylvania
    I used this mod.http://www.xtremesystems.org/forums/...8&d=1207145797
    I measured the voltage using one of the SMD capacitors circled in this picture.http://shrani.si/f/2t/Eu/4DFq8Vki/image07.jpg
    The cooling was stock.(probably not such a great idea)
    Engineering The Xtreme
    Feb 2007
    MA, USA
    you were measuring the voltage at load correct?
    Mar 2008
    Pennsylvania
    Yes, in the few hours before it burned up the biggest load it ever had was the Vista Basic theme.
    Wuf
    Jul 2007
    Finland/Tampere
    May not be impossible to fix, just little more challeging than normaly
    You use IRC and Crunch in Xs WCG team? Join #xs.wcg @ Quakenet
    [22:53:09] [@Jaco-XS] i'm gonna overclock this damn box!
    Ze gear:
    Main rig: W3520 + 12GB ddr3 + Gigabyte X58A-UD3R rev2.0! + HD7970 + HD6350 DMS59 + HX520 + 2x X25-E 32gig R0 + Bunch of HDDs.
    ESXI: Dell C6100 XS23-TY3 Node - 1x L5630 + 24GB ECC REG + Brocade 1020 10GbE
    ZFS Server: Supermicro 826E1 + Supermicro X8DAH+-F + 1x L5630 + 24GB ECC REG + 10x 3TB HDDs + Brocade 1020 10GbE
    Lappy!: Lenovo Thinkpad W500: T9600 + 8GB + FireGL v5700 + 128GB Samsung 830 + 320GB 2.5" in ze dvd slot + 1920x1200 @ 15.4"
    all outta gum
    Dec 2006
    Poland
    Card would be in 2D power state when displaying desktop, seems like 1,3 V was your idle voltage
    www.teampclab.pl
    MOA 2009 Poland #2, AMD Black Ops 2010, MOA 2011 Poland #1, MOA 2011 EMEA #12
    Test bench: empty
    Xtreme Legend
    Nov 2002
    Sweden
    Quote Originally Posted by xoqolatl View Post
    If the 2D voltage was 1.3V, I wonder what the 3D voltage would be
  18. #18
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    That part is de facto the first thing to crap out on G92 board. I had one GT blow this way and I've seen several cards have died this way online.
    Too bad fets of that form factor are a major pain to solder. In and out.
    With only one soldering iron atleast.
    edit:
    Wait? It died on desktop, in idle?
    Sounds like it was not vmod related. That exact part simply cannot be overvolted to death and in idle it cant choke on current either.
    I'd take out the mod and RMA.
    You were not supposed to see this.
  19. #19
    Apr 2008
    I would cut the GPU out and make it a keychain....
  20. #20
    Nov 2005
    New Hampshire
    Quote Originally Posted by Burnt Toast View Post
    Brother does your nic go with this thread.
    That card is burnt and it is toast!
  21. #21
    Xtreme Cruncher
    Jan 2009
    The Hague, Netherlands
    This poor guy is still giving first aid to his card and you guys are already talking about keychains.
    3770K 4.7Ghz 1.32v / ASUS P8Z77-V PRO / 8GB DDR3 1866 9-9-9-27 /ASUS HD7970 1025MHz / Antec NeoHE 550 / Samsung 830 256GB Crunching
    Cooled by PA120.3, EK-HF, D-tek Fuzion GFX, DDC3.1 XSPC res/top
    i5 2400 Stock / ASUS P8P67 LE / 4GB DDR3 1600 / Seasonic S12II 430W / Intel G2 40GB Crunching
    2600K 4.6Ghz 1.34v / ASUS P8Z68-V PRO / 8GB DDR3 1600 8-8-8-24 / Antec 430W / Intel G2 80GB Crunching
    W3520 4.0Ghz 1.19v / Rampage II Gene / 6GB Kinston Value 1333 / 9800GT / Corsair TX650 / Antec mini P180 / Intel G2 160GB Crunching
    Intel G860 Stock / Gigabyte H67MA-UD2H-B3 / 4GB DDR3 1333 / Antec Earthwatts green 380W / Crucial M4 64GB Crunching
    E6600 3.2Ghz 1.36v - P5B Deluxe / i7 930 4.0Ghz 1.29v - ASUS P6X58D-E / Q9450 3.6Ghz 1.28v - Rampage Formula Retired
  22. #22
    Apr 2008
    Quote Originally Posted by Conquistador SW View Post
    Of course...a shiney 9800GTX keychain would be awesome!
