hi i have 8 gigs of corsair xms2 pc6400c5 ver 4.2ram.i want to know what are the safest volts to use and roughly how these would overclock.i have a gigabyte p35c ds3r rev 1 motherboard and q6600 cpu.
thanks
asifqabil
thanks
asifqabil
bump
Please give us time to respond before bumping threads. There is a time difference.
Do not exceed 2.1v with these modules. As for OCing, you may have a difficult time on a P35 chipset OCing with 4 modules due to the load on the memory controller. You'll need to increase your memory controller voltage. The only way to know is for you to set the BIOS and test for stability.
Yes, Yellowbeard, a tall rough man with a big yellow beard
ok, sorry for the bump...thanx.
i have tried but no luck, what exact settings do i need ?.
thanx
