Source: ExpreviewWe have already introduced Galaxy’s non-reference GTX285 last week, and the reseachers from Galaxy have tried out a different cooler on it.
This custom cooler employs two big fans with diameter of 100mm to ensure enough air flow and to reduce the noise efficiently. The cooler claims to be able to reduce the noise by more than 20dB compared with reference sample. As we can see, the cooler is put close to the right side of PCB, which is designed to enhance the cooling for power supply part.
Featuring the third-party chip to support DisplayPort, this card also offers DVI and S-Video connectivity. The GDDR3 memory chips carry the model number H5RS1H23MFR-N2C which are specified to run at 1200 MHz. Instead of 16MX32bit on most GTX285, Galaxy has chosen 32MX32bit to form memory size of 2GB.
However, the final edition will feature Arctic Cooling Accelero Xtreme cooler.
