Results 1 to 11 of 11
Thread: plz help me whit a problem,i tri to oc my skulli
    Mar 2008
    belgium, wervik
    i have problem whit my skulli.
    it runs fine at stock and lower but if i try to oc it a bit its not stabel.
    it boot @4ghz but 3Dmark dont finich.
    Vcore @ 1,4v
    al the rest @ stock
    temp @ 4 ghz ar low 60°c
    this ar the specs for the rest of the system
    2 zalman 9500 stock temps 45 °c max
    2x QX9775
    intel D5400XS
    4x1 fsb 667mhz kingstone
    1 WD3200AAJS
    1 dvd-read
    1 dvd-rw
    1 asus ati 3870 top
    cooler master UCP 900W
    what dos this messegs meens.
Name:	Herschaalde kopie van 002.jpg
    Mar 2008
    belgium, wervik
    plz help me to find a solution for my problem.
    the problem strats to pop up 3.7Ghz even Vcore @ 1.4, it boots Vcore @ stock .
    if i khan reatch 4Ghz on air i gone put a wc on it.if not the system gone be at stock for the rest of is live.
    zo plz help to find my goal of 4Ghz on air befor wasting monny on wc parts for a stock system
    Feb 2009
    I've just learned myself that 101 code means you need more vcore
    Mar 2008
    belgium, wervik
    thx.but iz it ok to go above 1,4 on air whit temps @ 60°c full load
    Feb 2009
    I don't know about your chip but i have an i7 and push it 1.435, but its under water. i wish i could help you further.
    Mar 2008
    belgium, wervik
    thx suprafill for you replay.
    plz khan anibadi whit the qx9775 post the save max Vcore and max temp.
    what whil be the best air cooler to upgraid the zalman9500. it dozent fit normal on the second cpu
    my cpu's ar slany 3746b608 - 3574706 - 1a0300 and the other is slany 3746b608 - 3574706 - 1b1468
    Mar 2008
    belgium, wervik
    pzl help, how khan i fix it.
    1,45Vcore i khan do Wprime 32M and 1024M but 3dmark vantage fails at the physics test.
    somtimes i got,hardware stop cal your hardware vendor or the pich in my other post
    the temp @1,45Vcore ar low 60°c at full load
    Mar 2008
    belgium, wervik
    i just did it.a kompleet run of 3dmark vantage at 4G whit vcore 1,5 but the temps on air ar realy hi.
    ar those tmeps ok for this speed whit my zalman coolers
    http://www.hwbot.org/result.do?resultId=834015
    low temp
    cpu 1 / core 0 = 23°c , core 1 = 23°c , core 2 = 35°c , core 3 = 35°c
    cpu 2 / core 0 = 42°c , core 1 = 36°c , core 2 = 41°c , core 3 = 41°c
    max temp
    cpu 1 / core 0 = 58°c , core 1 = 54°c , core 2 = 56°c , core 3 = 54°c.
    cpu 2 / core 0 = 68°c , core 1 = 64°c , core 2 = 64°c , core 3 = 62°c
    Mar 2008
    belgium, wervik
    its stil unstabel.just have an other stop messegs dit not have the time to take a pic from the messegs.
    back to stock speed
    Xtreme Cruncher
    Mar 2009
    Republic of Texas
    I have a Skulltrail and I stay at 3.60ghz till I get H2O
    Mar 2008
    belgium, wervik
    Quote Originally Posted by Blake View Post
    what ar your temps and settigs for 3.60ghz
