I have a Asus P6T Deluxe with a 920 i7 & corsair dominator 1600MHz memory. Does anyone have a template of their bios settings to overclock to at least 3.6GHz?
right now I can't get much past 3.4 without it locking up on me. Thanks for all your help!
All I do is
XMP profile OC
manually specify multiplier
specify BCLK (can go to about 215)
Drop QPI voltage from 1.4 down to 1.3-1.35
Specify RAM speed (make sure its not too high really don't see much going from 1200 to 1520 so I use 1200 for 24/7).
Specifiy Vcore (1.075 @ 3.6 / 1.145 @ 3.8 / 1.225 @ 4)
I can prime at 3.8 with HT on or 4.0 off and only because it gets too hot.
What is this XMP? I have this as well, and I tend to just do manual profile.
Lian-Li Armorsuit PC-P80 Asus P6T Deluxe w/ OC Palm| TFC X-Changer 360 x2
Intel i7 965 Extreme Edition | Swiftech Apogee GTZ
Asus GTX 295 x 2 (Quad-SLi) | Koolance VID-NX295 x 2
Velociraptor 300GB | Swiftech MCP655 Pump x 2
G.SKILL PI Black 6GB | EK 250ml Reservoir
Tygon 7/16 Tubing | Enermax Revolution 85+ 1050w Fully Sleeved
Just pulls the extra settings from RAM. Notice I overide a few of those settings anyways.
ewitte you said to manually specify cpu ratio setting,? what to?
Hmm... I'll give it a try when I get home. I have a small fear of overclocking and burning something out when it comes to voltages.
19 and 20 mostly. The 21 multiplier doesn't like to be stable. Will try it more when I switch over to water.
install the 1303 bios
The 21x is now selectable for the 920 retail version
Asus Rampage II Gene | Core i7 920 | 6*2GB Mushkin 998729 | BFG GTX280 OCX | Auzentech X-Fi Forte | Corsair VX550
—Life is too short to be bound by the moral, ethical and legal constraints imposed on us by modern day society.
