For CPU I'll probably use Silver, but EK quite rightly suggests using Céramique as the Artic Silver 5 can have slight capacitive effects.
What does everyone used in terms of compund?
IC Diamond! It's a to apply, but it gives you lower temps than anything else out there.
LINK
I have and use both Ceramique and AS5. I like them both. I tend to use the AS5 on processors, and the Ceramique on RAM, etc. The Ceramique is much thicker than AS5.
if its a cpu with an ihs it dosnt matter, and i use mx2 since the diamond stuff can scratch stuff up
5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
MX-2 here. Crap that reminds me, I think I'm out of MX-2.
MX2 for me as well. Although I got slightly better results using Liquid Metal Pro, but that stuff is impossible to get off and can weld your wb to the cpu.
MX2 for me too, no break in time etc...
i us mx2 here also
My Loop: mcr320/d5 vario/d tek fuzion/3x ultra kaze 2000's Case: Modified RocketFish Rig: AMD 720BE X3 Biostar TA790GX A3+ Super Talent 2x2GB WD 320AAKS His HD3870x2 Ultra X3 600W
I just got my Big Tube of IC Diamond from Petras today. Had Ceramique on it and i9t dropped temps 3c off the Gate
SuperMicro X8SAX
Xeon 5620
12GB - Crucial ECC DDR3 1333
Intel 520 180GB Cherryville
Areca 1231ML ~ 2~ 250GB Seagate ES.2 ~ Raid 0 ~ 4~ Hitachi 5K3000 2TB ~ Raid 6 ~
I typically use MX-2 but IC7 is some great stuff, but yes diamonds are abrasive and do a nice job of removing cpu print.
Think of it as a mini-lapping.
XSWCG Disclaimer:
We are not responsible for the large sums of money that you WILL want to spend to upgrade and add additional equipment. This is an addiction and the forum takes no responsibility morally or financially for the equipment and therapy cost. Thank you and have a great day.
Sigmund Freud said... "Failure to CRUNCH is a sign of Sexual Inadequacies".
MX2 all the way.
Asus Rampage Formula X48
Intel Q9650 @ 4.33GHZ
OCZ Platinum DDR2-800
Palit 4870x2
Creative Xi-Fi Extreme Music
Corsair HX1000
LL 343B Case
Thermochill 120.3
2xMCP355
KL 350AT
KL 4870X2 FC WB
DD Chipset Block
i've used AS5 and IC Diamond.
IC Diamond is a pain in the ass to apply. i dont think its worth it. any margin of error equates any benefits of IC Diamond with the simple to apply AS5.
what is that TIM that comes with Swiftech CPU Blocks in that white no sticker tube
swiftech gives AS ceramiq
+1 for MX2. Mmuch easier to clean off and reapply than AS5 for me.
mx2 is better but it dosnt make that much of a difference
i like this
http://www.petrastechshop.com/arcomxthco3.html
IC7 is Best ,, Can out last the CPU when applied correctly.(must be exact when applying for best results)
AS5 works for a majority of stock to High/Medium Overclocks
" Needs reapplication after a period of use."
Ceramique..is nice for lapped IHS/HS/WB .. but does NOT cool as good under High load like As5.(cleans up easier that AS5)
MX-!! is my favoriate,, Apply correctly once and no need to apply again,,
MX-!! tolarates heat above 1.7volts . Applies very well and Cleans up nice between CPU changes .
IC7 for the Extreme Overclocker ,,
MX-!! (Easier to get a hand on) Outperforms AS5) keeping Load temps Cooler and dosnt need curing time!.
Now for the average joe ,, one can use Ceramique for Mild Overclocks or Stock applications ..
All Four paste above will show simalar Idle Temps when applied correctly.
IC7 or Mx-!! ,,they just perform the Coolest under High volts and High loads 24/7.
+1 Ic7
whats the best way to apply AS Ceramic for the GTZ + Q6600?
thin line? green pea sized in the middle? pea sized then spread with a card?
Another vote for ic7. I switched from MX-2.
--Matt
My Rig :
Core i5 4570S - ASUS Z87I-DELUXE - 16GB Mushkin Blackline DDR3-2400 - 256GB Plextor M5 Pro Xtreme
