I noticed this with P05 and G30 (my BlackOps current BIOS).
There is something strange with the names of the last 3 hard disks.
These are the names when the HD-controller is in IDE mode :
(These names are correct.)
But these are the names when the HD-controller is in either RAID or AHCI mode :
(From SCSI-3 it is a bit of mystery meat to determine which one is the second HD103UJ. If you want to move it to the top.)
While booting the correct names/sequence are shown :
(But it's difficult to select it at that stage.)
And while we're at it. How do I get rid off the "Press any key to continue ..." pause at the JMicron controller splash ?
Are the human readable GTL Ref voltages that were promised in this topic already in a public (beta) BIOS : BlackOps/Avenger: GTL Ref Table
Also it seems that none of the 1:4 CPU??? dividers works with 8GB RAM installed. Is this correct ?
1:4 CPU200 = OC recovery
1:4 CPU266 = Memory panick bleeps
1:4 CPU333 = OC recovery
1:4 CPU400 = Boots, but Memtest86+ v2.11 test #5 98% errors, Memtest86+ v2.11 test #8 instant errors, Vista will complain about hardware or software change : winload.exe (0xc0000221), 8GB@1780Mhz results in corrupted BIOS settings.
EDIT2: More about the 1:4 dividers over at OCZ : Help needed to stabilise 8gb OCZ3P20004GK on Foxconn BlackOps
Robert
Corrupted BIOS settings :
