Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: Need vdimm mod for Soltek 75frn2
    Jan 2003
    I have looked all over and nobody has a vdimm mod for this board. I all ready have the vcore mod. Anybody got any ideas??
    Thanks...
    Member
    Dec 2002
    Leics UK
    I havent seen one.
    If you can give me a high res pic of the memory voltage regulation I can look into it.
    boughetto overclocker
    Jun 2002
    NORAD Command Center
    Well I got some pictures of the board, but I have no idea which chip it is... lemme link you. This is from a while ago, and when I asked, everyone was stumped as well... perhaps some light will be shed as to which it is this time around.
    http://www.maximumoc.com/img/hardwar...s_possibly.jpg
    Dinosaurs are chortling.
    Lian Li PC1200B, Custom Water Cooling, Lamptron FC5 Fan Controller w/ 4x 120mmx38 Deltas
    i7 930 @ 3.8ghz, Rampage III Extreme, 12GB G.Skill PC2000, BFG 260GTXOC, PNY Quadro 380FX
    (1) HP LP2475w 24", (2) Dell 2007WFP 20", Corsair AX1200 1200w, 3Ware 9650SE Raid
    (2) 500gb Hybrid Seagate Raid 1, (2) 2TB WD Red NAS 64mb Raid 1, (5) 1TB Hitachi 32mb Raid 5
    Member
    Dec 2002
    Leics UK
    Ok,
    I think I have it.
    The chip we are looking at is the FAn5063 in your pic.
    http://www.fairchildsemi.com/ds/FA/FAN5063.pdf
    Pin 7 is the FB pin into a classic resistor devider.
    I cant see where any of the traces on the board go due to the horrid gold PCB so you will have to look with your eye.
    I have coloured what I think is 7 in this pic, providing that I have the chip orientation correct, you should double check this first as im not sure if the "dot" I see on one corner is the pin1 ID dot or just some splashed flux... so be carefull.
    Start with a big VR (1MO is my prefered) and drop down if there is little effect once you hit 500k, and so on that way you stay safe.
    EDIT - THE ABOVE IS INCORRECT.. I SCREWED UP.. SEE BELOW FOR FIX
    Attached Images Attached Images
    Technician
    Jun 2002
    Merseyside, UK
    That looks more like the vTT area than the vDDQ area holst. Could be wrong though - that pcb is a pain in the ass. The ampage of that FAN vreg seems a little low is all. If it was vTT itd be fine, but as a total vdimm controller itd seem to be a bit lacking.
    Any chance of a photo of the lower end of the dimm slots?
    PiLsY.
    Jun 2002
    Yeah I can snap one for ya tonight
    Member
    Dec 2002
    Leics UK
    PiLsY.
    It could be, its hard to tell without testing the board with a meter.
    Im pretty sure im right, soltek will use what works it wont necicaraly be impressive looking. Wont hurt to look elsewhere though just to be sure.
    A wider angle pic would definatley help, thanks sysfailur.
    Dec 2003
    [Originally posted by Holst [/i]
    Ok,
    I think I have it.
    [/QUOTE]
    I will try to do the mod at pin 7 but from the chips technical specifications I am not sure if pin 7 is the right pin. The pin you show with the arrow is indeed pin 7 (top left is pin 1). What should pin 7 stand for?
    Dec 2003
    This is what pin7 is according to the data sheet.
    SLP_S3. Control signal governing the Soft Off state S3. Internal current source pulls this line high if left open.
    Dec 2003
    Any ideas if pin 7 is the right pin? I got a 1MÙ vr and I will try to do the mod but I need to confirm if this is the right pin.
    Dec 2003
    this is a pict with the voltage measurements on my mobo with vcore of 1.95 and a vdimm 2.8 at the BIOS
    http://f1.pg.photos.yahoo.com/ph/nda...obovoltage.jpg
    Member
    Dec 2002
    Leics UK
    I dont know why I said 7, thats totaly wrong...
    I was thinking page 7 of the PDF.. must have got confused when writing it up... thanks for checking tristento.
    If you look at the PDF page 7 pins 12 and 13 are connected to the resistor devider... a VR from pin 12 to ground should do it..
    Sorry for the prior confusion... stupid me.
    Member
    Dec 2002
    Leics UK
    Your link is bad, can you make your pic smaller (or cut it into two bits) and upload it to the forum.
    Jan 2004
    uk
    when somebody tries this share your results, got the same board and i wanna try it as well.
    gone to central america with raleigh international, back in mid september.
    happy oc'ing everybody
    Xtreme X.I.P.
    Nov 2003
    Keller, TX
    Is pin 12 to pin 11 via VR, fine?
    Dec 2003
    Thanks for the reply Holst. In the meantime I got a DFI so no need for moding. However I am very interested to see if anyone finally makes the vdimm mod. I might even get my mobo back!!
    Jan 2003
    I see this board with RAID cheap here in Japan. What does the VCORE and VDIMM go to in the BIOS? Any chance of adjustable VDD?
  18. #18
    Jan 2004
    uk
    vcore 1.85
    vdimm 2.8
    does anyone know where to measure the vdimm voltage after youv done the mod?
  19. #19
    Dec 2003
    Brisbane, Australia
    Golden Flamer has performed this mod. He writes about it here on page 21, 22 of the thread. He also said that he added capacitors, an inductance wire and a connection of his 3.3 volt to one of the mosfet drains for additional voltage stability. We hope that he'll post more details on what exactly he has done.
    Cheers,
    RnR
  20. #20
    Feb 2004
    Here I Am!
    I'm Italian, sorry if I write bad english
    Read my signature!
    My system pass all PRIME95 torture test and my board is Rock-solid stable.
    I can raise V-dimm Voltage up to 3,25V!
    Wait for next week, I Prepare a guide.
    HOLST: your solution work Ok but it is not sufficient to guarantee system stability, there is another two issue to fix.
    I post details next week!
    DFI Lanparty NF3 UT250GB V-Dimm Modded @ 255
    A64 Newcastle 3000+ Step CG @ 2550MHz @ 1.6V
    1x512Mb Corsair PC3500 + 1x256 Mb Mushkin LvL II
    All in Wonder 9800SE@PRO 8pipe 256bit@ 462/790
    Creative Audigy2 Platinum
    2xSEAGATE 160GB SATA Ncq RAID 0
  21. #21
    Jan 2004
    uk
    Originally posted by GOLDEN FLAMER
    Here I Am!
    Read my signature!
    great, thanks for info golden flamer
  22. #22
    Feb 2004
    BOYZ, HERE is the link to my VDIMM Mod guide:
    http://forums.amdmb.com/showthread.p...91#post2551991
  23. #23
    Member
    Dec 2002
    Leics UK
    Thanks for the work golden flamer, im looking forward to seeing more of your stuff in the future.
  24. #24
    Jan 2004
    uk
    guys i've tried this mod and it works great, i can now set my ram at 3.2v where as before the maximum was 2.8v, bring on some new benchmark scores :-)
  25. #25
    Xtreme X.I.P.
    Nov 2003
    Keller, TX
    Have a question here. GF uses the 3.3v rail to feed more volts to the FET, otherwise vdimm won't pass 3v. I am assuming this 'cause I have a costumer's Soltek here for modding and, after doing the vdimm mod with a 200k trimmer, the thing won't go above 3v.
    What is the possibility of feeding the FET with the 5v rail? Any risk in doing so?
