Project LogsWork in progress ideas are more than welcome.
I would like to say thanks to Cyber who got me out working on this old box.
First off it was well buried LOL
And need to get all the guts out of course before I can even start thinking about how to do what inside.
Door rads should fit right on, or anything else I might want to install
I could rig these up to an old controller for racing games....thinking about it
Money box is being a pain to remove
All this has to come out
Monitor 4 screws and it popped out VERY EASY steering well and gear also the same way.
Old school Hmmm could replace with new
Test fit with a 24'' lcd might use a 19 for this dont know yet....
More to come first day
latest updates
03-16-2009, 03:16 PM
A little help from old tires LOL
Cut me a hole
Sub fits JUST RIGHT!!
In between the cubit is a channel for speaker wire/ echo for bass
Going to keep the original outside as much as possible. Still debating it, but I think it's the right idea.....
03-16-2009, 08:30 PM
Installed
Space
wires to front
Hmmm on top
LET ME JUST SAY OMG
OMG
and OMG
IT POUNDS HARD
Really I have never hear that 5.1 system sound so good. I'm highly impressed with this old cabinet so far.
03-30-2009, 03:31 AM
Ok funds have been slowing this down....
Plans
I am painting it black. Old school is going out the window.
Now I want to make this a AMD Machine. I'm thinking of Ruby on the back, and a spider on the side. I want some kind of window to look into the machine to see the hardware, and thinking of making a giant falling rez ontop of the machine....
Also I would like to find some PCI-E ribbon extenders for this mod.
OR
AMD in a 2 level res one to trace out AMD and behind it the other color to balance out the logo.
I'm thinking of having a sticker made IDK....or drawing it in some fashion....
Old 04-02-2009, 09:26 PM
Found some cash to buy a can of paint today.....only did one side so far.
Speaker cables I was talking about are the rear.....
Anyways as you can see it's going to have to be sanded down from the primer paint.
The bubbles are from the duck tape that I thought I had removed....
Update
04-14-2009
My lights for running boards
I think they are going to work great
The new 24'' LCD installed
in action
From behind
PS3 test machine
update 04-18-2009, 06:33 AM
So here is the backboard
The original speakers are gone....They mounted on more or less backwards from what normal speakers mount like. I had to make room for the new ones to fit in this manor
My trace
My not so perfect cut
A little off but you can't see it, and I don't think it will really matter
You can only see threw the grills with the flash.
So in my world what I did works(the other was installed the same way)
BTW I'm addicted to this box now....PS3 is played in this thing at least 3 hours a day....The sound is AMAZING in it!
BUT I am going for a AMD Build inside of it.
I know now that I'm going to have to install a small AC unit in this box with doors.
Me and my son have black blankets being used as doors ATM.
OK going for a AMD Build soooo
After the lament installed, then I need to find someone to make me a Dragon sticker to slap on it.
Something like that but not that.
